AC Vents
Old Jul 23, 2012 | 05:37 PM
blublzr's Avatar
blublzr
Default AC Vents
I have 2009 crew cab and the AC will only blow out through the floor vents. It will start blowing at the dash and then start making a poping sound and start blowing out at the floor. What is the the problem and how much do you think it will cost to get it fixed?
Old Jul 24, 2012 | 08:04 AM
kddsRam's Avatar
kddsRam
There was a safety recall - K17- for this. Should do the same when in defrost mode. Mine was in once for the recall notice, then again when the actuator went bad and they replaced it that time and did the reflash again..
Old Jul 24, 2012 | 11:59 AM
DodgeCares's Avatar
DodgeCares
Blublzr,
Below is a copy of the recall if that is indeed your issue.
Customer Satisfaction Notification K17
Reprogram HVAC Control Head and Inspect/Replace
Actuators
2009-2010 (DS) Ram Truck (1500 series)
2010 (DJ) Ram Truck (2500 series)
2010 (D2) Ram Truck (3500 series)
NOTE: This recall applies only to the above vehicles built through May 22, 2010
(MDH 052220).
The HVAC mode door actuator gears on about 225,000 of the above vehicles may
break and result in the inability to fully control the HVAC functions.
All involved vehicles must have updated HVAC control head software installed
and the mode door actuators must be tested and replaced as required.
Old Jul 24, 2012 | 01:54 PM
laramie09's Avatar
laramie09
I just had to replace an actuator. $37 from the dealer. Have to take apart the whole center section of the dash.
Old Jul 25, 2012 | 09:17 AM
blublzr's Avatar
blublzr
Thanks to all! I'm going to have the dealer change the oil (Have Coupon 4 oil changes for $60) and will see if they can make the repair as part of the recall. If not maybe it want brake the bank to have them replace actuator.
Old Jul 27, 2012 | 02:54 PM
Saga13mx's Avatar
Saga13mx
Has anybody had any success to get this fixed under that recall mentioned above? I'm having the same problem as the OP
Old Jul 28, 2012 | 11:44 AM
2k10HemiRam's Avatar
2k10HemiRam
Mine was fixed under the recall, I had no problems with the a/c before hand either as my truck was only a few months old.
Old Jul 29, 2012 | 12:05 PM
oldjeep's Avatar
oldjeep
Mine was fixed soon after the recall came out - it had already broken the part which they replaced. It was a pretty long service appointment so plan on leaving it for the dat.
Old Jul 30, 2012 | 01:04 AM
RGVram99's Avatar
RGVram99
My 2009 CC just started doing the same thing a couple of days ago. I had the dealer do the recall check/inspection a while back when this notice first came out, now my truck has 40K miles and is out side of the 3/36K warranty. Am I still covered under the recall? If not how much will the repair cost?
Old Jul 30, 2012 | 08:14 AM
DodgeCares's Avatar
DodgeCares
RGV,
If your vehicle has a recall on it then it will be repaired even if you are out of warranty.
