K 36 Recall
Old Jul 25, 2012 | 06:59 PM
Spdbird's Avatar
Spdbird
Default K 36 Recall
The recall has pictures of the open diff showing how to install the axle fluid drain back flow restrictor. I have purchased the kit (CBLOK360AA) just to get the new rear end cover. New cover prevents you from adding fluid (19 oz) thru the vent tube. My truck has a build date 4-11 and didn't fall under the recall but I still have the old rear end cover. I am assuming my rear end came from the factory with the fluid drain back restrictor, just need to replace the cover. I called Ram customer service (800#) for the recall, no luck.
Could some one help me obtain the recall w/pictures. Thanks for your time.
Old Jul 26, 2012 | 09:57 PM
jasonw's Avatar
jasonw
Site Moderator
https://dodgeforum.com/forum/dodge-r...s-section.html
Old Jul 27, 2012 | 07:18 AM
thiggins's Avatar
thiggins
If I were you, I'd go ahead and put a "real" cover on it, and get the Mag-Hytec.
Old Jul 27, 2012 | 01:44 PM
Spdbird's Avatar
Spdbird
Default K 36 recall
JasonW, sorry for the miscue.
thiggins, the last time I checked with Mag-Hytec they were unaware the Ram switched to ZF differential. Haven't check with them lately.
Old Jul 27, 2012 | 02:17 PM
thiggins's Avatar
thiggins
I have the Mag-Hytec cover. It fits.
