Im going to strangle chrysler!!!
Old Aug 21, 2012 | 08:42 PM
  #41
krp2012's Avatar
krp2012
Originally Posted by OhFive_Daytona
My thought... Sport Tuner. Find a used one that's unlocked for under $100 if possible. Throw that on there, and feel the increased power. Or... Throw a bottle of fuel treatment in your tank after you fill up next time $8 a bottle. Or! You just got a gutless wonder of a truck by getting a 4.7, and what did you drive before that? You may just be used to the power you have. I drive a 2005 5.7 Hemi Ram which is awesome. I get into my 2002 4.7 Durango... WIMPY.
I drove a v6 chevy. Lol. Thats not it. And im not sure how familiar u are with all this but um my wimpy gutless 4.7l makes as much hp as your 7 yr old 5.7. And fuel cleaner over the counter is garbage. I ran a concentrated proffesional grade injector cleanor thru it. Did nada.
Old Aug 21, 2012 | 08:44 PM
  #42
krp2012's Avatar
krp2012
Originally Posted by Pedro Dog
So what's your 0-60 with less than a 1/4 tank and not acting up? Asking what others get is comparing apples to oranges - no two trucks are the same, gears, tires, etc.
Since it started with a fill up, you need to change the fuel filter or add some additive to the tank to clean it out.
Im not asking to match times. Just an approximation. If someone ia running 8 secs and thats avg then its good to know. And there is no fuel filter on these trucks.
Old Aug 21, 2012 | 10:23 PM
  #43
hounddogg's Avatar
hounddogg
Filter is replaceable. Its in the fuel pump module. Its a pain in the butt. Not usually done. Need to hook a fuel psi gauge to it an tape it to the windshield so you can read then drive the vehicle.
Old Aug 28, 2012 | 09:57 AM
  #44
krp2012's Avatar
krp2012
after taking the truck in to the dyno yesterday, some useful things came out of it.
#1 the truck is putting down 162 hp @ 5400 rpm and 165 tq at 4500 rpm.
the equivalent of a honda civic.
the other thing is the right rear caliper is locking up, 25k mi thats crazy.
i took a IR tme gun to the rear rotors during the dyno due to a suspicion and the right rear rotor measued almost 450 degrees while the other 3 were at or around 110.
so look like ill be taking it back to the dealer today as well as giving chrysler a call asking them why during 4 trips to the dealer this was never found.
Old Aug 28, 2012 | 01:34 PM
  #45
oldjeep's Avatar
oldjeep
Seems like you should be getting around 225HP - but if your brake is dragging then the readings are all screwed up
Old Aug 28, 2012 | 05:08 PM
  #46
hounddogg's Avatar
hounddogg
I've heard of numerous calipers seizing. Thank goodness its under warranty. Saw one at the dealer the other day with one front and one rear seized.
Old Aug 30, 2012 | 11:21 PM
  #47
redhemi06's Avatar
redhemi06
ha so this whole time it was just your caliper seized? couldnt smell the pad burning?
Old Aug 31, 2012 | 11:30 AM
  #48
12Sport's Avatar
12Sport
Seems even a mechanic with 15 years experience missed that one.
Old Aug 31, 2012 | 12:21 PM
  #49
hounddogg's Avatar
hounddogg
Easy to miss unless its hard seized and obviously that one wasn't.
Old Aug 31, 2012 | 01:07 PM
  #50
dankent's Avatar
dankent
Well, i will have to keep my eyes out for that one.... weird problems.
