air lift 1000 installed
Old Sep 5, 2012 | 08:38 AM
12Sport's Avatar
12Sport
Originally Posted by oldjeep
He said the equalizer is "The hitch is 1000/10000 equalizer", so he is pushing the upper limit of the tounge weight
940 tounge weight on a 6000 lb trailer seems excessive though. 15% is a max suggested tounge weight and you're over that. I tend to run less than 10%, but it depends on the trailer.
Yeah, I read that. My question is what's the rated capacity of the equalizer bars he has, not the hitch. Too light and you can't get enough lift.
Old Sep 5, 2012 | 08:56 AM
oldjeep's Avatar
oldjeep
You lost me, with that hitch they should be 1000lb bars at the max setting.
Old Sep 5, 2012 | 09:23 AM
dirtydog's Avatar
dirtydog
Moderate User
I've been pulling trailers for a long time and if set up properly with the correct bar capacity and head angle combination you shouldn't need any air bags to level your rig out. Save the air bags for other uses.
I've towed quite a bit as well. And while I have the '08 with leafs, the airbags are freakin awesome!
Practically zero *** end bounce going over bumps. Truck handles like a dream around corners and doesn't have excessive roll.
On take offs, the truck lifts up evenly rather than sagging down in the back and lifting the nose to the sky.
Forgetting about *** end sag and it's downfalls, those 3 reasons above are well worth airbags alone!
OP;
swaying from the back end side-side is not a good thing and is not something airbags can stop or prevent. The root cause of this is improper loading/weight distribution on the towing axle.(too much tongue weight)
The most airbags can do is lift the tongue up high enough where the weight gets transferred more to the center. It's a bandaid fix and requires changing load around on trailer or using a weight distro hitch..Preferrably both!
Old Sep 5, 2012 | 10:55 AM
12Sport's Avatar
12Sport
That's what I'm trying to find out - what bars are being used? 800s, 1000s, 1200s? Perhaps what he is using are too light.
Old Sep 5, 2012 | 10:58 AM
12Sport's Avatar
12Sport
Can't relate to that. Never experienced any of that with any of my setups.
Old Sep 5, 2012 | 12:19 PM
oldjeep's Avatar
oldjeep
He said it is a 1000/10000 - that means 1000lb bars
600lbs bars would be a 600/10000
1200 would be a 1200/10000
and so on.
TW/GTW
Old Sep 5, 2012 | 03:54 PM
12Sport's Avatar
12Sport
and so on.
TW/GTW
LOL I'm just wanting clarification. He said the hitch is 1000/10000. The hitch is the part bolted to the truck. The bars don't have a towing capacity - they just provide lift. If he meant the bars fine but that's not how I'm reading it.
My apologies to capsfloyd.
