Valve stem warning.
Old Sep 15, 2012 | 12:07 PM
RAMULAK's Avatar
RAMULAK
Default Valve stem warning.
I highly suggest everyone go check their valve stems. I know there was already a post on this earlier from someone that had a failure, but I went to do my brakes today and found both my front rims have cracked valve stems. I have Maxcare 7/70 so they are covered however I have a $100.00 deductible. But still at $80.00 per piece or at least that is what they said....Better than nothing. Now I just have to drive 86 miles one way to get to my dealer.
Argh!
Oh, and BTW my brake pads still had 1/2 the pads at 52,000. I proably could have waited until Spring to change them out......Just an FYI.
Old Sep 15, 2012 | 08:54 PM
oldjeep's Avatar
oldjeep
Originally Posted by RAMULAK
I started my own thread about mine, just so people would go check theirs.
Found both my front tires stems cracked while I was doing my brakes today. When I called the dealer they said $80.00 a piece. I have 7/70 and they said they were covered but I have a $100.00 deductible so it really doesn't help that much.
You don't need to replace the whole tpms. Any tire store will have the kit and stem. parts cost is around $15 from the tire store or $8 at the local auto parts store
Stem:
http://www.oreillyauto.com/site/c/de...5431&ppt=C0033
Kit:
Old Sep 16, 2012 | 07:10 PM
cpelton's Avatar
cpelton
You do have to replace them, the threads corrode and then crack the nut. I've had two tires lose air because of is. Should have been a recall IMO. When that nut falls off theres nothing holding the valve stem sealed against the rim, one big bump and it falls into the tire and rapidly deflates.
Old Sep 16, 2012 | 07:15 PM
oldjeep's Avatar
oldjeep
You do have to replace what? Not the whole TPMS - just the stem and nut/seal kit. Just had one done on thursday.
Old Sep 16, 2012 | 07:56 PM
Cmerritt84's Avatar
Cmerritt84
No issues on mine. I have no tpms sensors. I have regular plain-Jane valve stems on my rims.
Old Sep 16, 2012 | 09:00 PM
RAMULAK's Avatar
RAMULAK
Really? I thought they all had to have them now that some states check the TPMS system at safety inspection time. Well my snows are just gonna have stems and no TPMS's. Got an ppointment Friday to have the valve stems fixed. I just hope they don't let go on the way there.
Old Sep 16, 2012 | 09:15 PM
Cmerritt84's Avatar
Cmerritt84
I have no safety inspections or emissions in my county. I just turned TPMS off with my tuner so that stupid light stays off.
Old Sep 16, 2012 | 10:29 PM
crod's Avatar
crod
Yeah most big name tire places keep the kits on hand. They say it's rare they don't have to replace the stem when they do tires. About $8 a piece like other poster said
Old Sep 21, 2012 | 07:08 AM
VA4MEDS's Avatar
VA4MEDS
I'm glad the '10s don't have the nut on them. Just a pull thru type stem.
Old Sep 21, 2012 | 10:42 AM
LU229's Avatar
LU229
Argh!
Ramulak,
if you have them all replaced, tell your stealership to install the 2010 type, no nut, just pull thru style stem.
You can also just replace the nut like others have said, but make sure your threads are still decent on the stem.
