Last edit by: IB Advertising
Browse all: Dodge Ram 1500 Exterior Guides
- Dodge Ram 2009-Present: How to Replace Side Mirror
Step by step intructions for the do-it-yourself repairs.
Replace side mirror and housing 2010 Ram 1500
I caught the passenger side mirror on side of the garage and a piece of the mirror housing broke off. I'm unable to determine whether I need to remove the entire door panel to remove the mirror. There seems to be a separate plastic cover for that area at the upper left of the inside door panel, but I can find no info via searches whether that can be removed independently to access the screws and wire harness for the mirror.
A number of good how to videos can be found on youtube, but they do not cover 1500's later than 08, and in those you can clearly tell the door panel is one piece covering everything.
Looking therefore for the proper procedure to follow for 2010 Dodge Ram 1500 passenger side mirror assembly removal and replacement.
Job accomplished
I replaced the mirror assembly and found the post listrd at the bottom to be a great help. It gives a step by step explanation with photos on removing the door panel. It "might" have been possible to disconnect the wire connection by just popping up the lock/window control and reaching in to the connectors. They are to the left as you look down into the hole. Mine had three plugs in a vertical formation and the lowest one was the mirror. Pulling the wire out may have been difficult as it was secured to a plastic tab with electrical tape. About an inch down from the top of the door panel and about aligned with the right side of the mirror (as you would be looking from inside the vehicle) I don't know if you could get your hand up there from that lock/window hole to work that loose.
All in all the job went smooth. After removing all the stuff listed in the post referenced below the panel came off using a lift and wiggle technique. I also discovered that the plastic part around the handle can be popped off. It made things easier putting the panel back on as it gave more wiggle room around the handle. If you want to remove it use the same technique as described for the lock/window part. Pry from the left side as the right side has longer teeth to secure the part.
Replacing the door panel was the most difficult mostly because you are having to go by guess and feel.
My car repair skill is novice and this job took about an hour.
Replace the * with ram forum (no space)
http://www.********.com/f75/how-remo...r-panels-8955/
