Running board ripped off...
Old Sep 30, 2013 | 09:46 AM
  #21
WiseBuhl's Avatar
WiseBuhl
My son just told me about these, thanks - this is what I am going to do.
Old Jun 27, 2021 | 03:49 PM
  #22
mcnealc35@hotmail.com's Avatar
Default Did you use the sleeve or bulb?
[QUOTE=astroman54;2905663]I replaced the pulled out rivet nuts with these from McMaster Carr size M8x1.25.
http://www.mcmaster.com/#standard-rivet-nuts/=k4s30v
The larger flange made a sturdy install and the steps are back on using the same bolts as before.
Andy[/QUOTE
Which one did you use? Sleeve or bulb?
Old Sep 15, 2024 | 04:46 PM
  #23
Annabars12v's Avatar
Annabars12v
New rivnuts don't work too well if the old ones rusted out though or got damaged. Better to weld a plate for a reinforced surface, and switch to nuts and bolts instead of the crappy OEM mounts. Northspec Built has the kits for it: https://www.northspecbuilt.com/produ...-repair-plates
Old Sep 16, 2024 | 11:42 AM
  #24
sgmldr's Avatar
sgmldr
Default Same issue solution
Originally Posted by brandon633
Hello everybody,
I have a 2010 ram 1500 dbl cab w/ factory running boards. I was at the car wash the other day and the machine ripped off my running board on the drivers side. So I crawled underneath the truck and saw the great design of the running boards being attached to the body of the truck & not the frame, which all the mounting holes are now ripped apart. I'm kind of at a lose here, I spent a lot of money on these running boards so I don't want to throw them away. But unsure how to reattach w/ the damage that is done & how to resecure to keep this happening again. Or do I start from scratch and get another set, if another set does anybody have any ideas of a better set? Sorry for the long winded post, and thanks for your help in advanced...
Brandon
I recently bought a 20120 2500 mega cab and found the same issue. The running boards had been ripped of at some point ruining the mounting points. I bought the following running boards before discovering the problem. (https://www.ebay.com/itm/165874540585) Not to be defeated, I moved up about 1 1/2 inches above the existing, used the upper holes modified for the lower attachment points and cut new upper mounting points. They worked out great and are just a little over an inch higher than intended.
