Guys who have iridium plugs come inside!!!!
Old Dec 19, 2012 | 06:47 PM
AZdave's Avatar
AZdave
Originally Posted by SMGFATMAN71
2009 Ram 1500........Ive had the Densos for 50k.....never an issue...
Which Denso plug are you running?
Old Dec 20, 2012 | 07:48 AM
iskybantilus's Avatar
iskybantilus
Autolite double platinums for about 25k miles no problems here.
Old Dec 20, 2012 | 07:08 PM
SMGFATMAN71's Avatar
SMGFATMAN71
Denso part#IKH16.....iridium power.........With MSD coils........50k on that setup...71k on the truck total......runs great....
Old Dec 20, 2012 | 08:41 PM
1OF27's Avatar
1OF27
Just pulled factory plugs out of my '11 Laramie. They were NGK Platinums. Replaced them with NGKs Iridium offering. Truck runs as smooth as the day it came home. I had 2 plugs in the original set that had gapped out by about .005 over stock spec. Others were all within .002 at 31K miles. I hope I am good for 100K with the Iridiums...changing them was a 3 hour PITA.
Old Dec 21, 2012 | 04:52 AM
hounddogg's Avatar
hounddogg
You sure the factory plug was Platinum's? They are a 100,000 plug! They would not be due for replacement at 30,000. The nickel standard plug is the 30,000 mile plug. Did you check your owners manual for when to change plugs?
Old Dec 21, 2012 | 08:05 PM
bluedodgeram's Avatar
bluedodgeram
Thanks hounddogg for the heads up on the plugs, I will try the Autolite Iridiums when I'm due.
Old Dec 23, 2012 | 10:48 AM
kxwhite's Avatar
kxwhite
Just switched to the Autolite Iridiums also, truck is running as good as ever. I got tired of changing the OEM plugs every 30,000 so went with a longer lasting plug.
Old Dec 23, 2012 | 01:32 PM
LU229's Avatar
LU229
Whats the part number to the plugs you installed (???)
Old Dec 25, 2012 | 10:58 AM
hounddogg's Avatar
hounddogg
No answer? My 2009 it is Autolite XP 5325
Old Dec 26, 2012 | 07:44 PM
kxwhite's Avatar
kxwhite
Pretty sure thats the part number 5325... not at home to look
