temp gauge
Old Nov 25, 2012 | 09:48 AM
gtivr6's Avatar
gtivr6
Default temp gauge
do you guys notice your trucks temp gauge needle is never on the center. my shows that im around 193F and the needle is on the cooler side.
Old Nov 25, 2012 | 10:11 AM
CarGuyOhio's Avatar
CarGuyOhio
Nothing wrong with that.
Old Nov 25, 2012 | 02:17 PM
PostalTwo's Avatar
PostalTwo
yep thats where mine sits all the time once its warmed they got a 190 tstat
Old Nov 25, 2012 | 07:47 PM
gtivr6's Avatar
gtivr6
but why does it not sit in the center were the needle should sit. The center line maker. Its normal to see the needle sit on the center line marker.
Old Nov 25, 2012 | 07:50 PM
oldjeep's Avatar
oldjeep
Normal for what? Its normal for the needle to sit in the middle of the OK zone, not in the middle of the entire sweep
Old Nov 25, 2012 | 09:28 PM
POWER SEDAN's Avatar
POWER SEDAN
If your thermostat is a 190, and functioning properly, your going to see readings generally around the 190 indication on the temp gauge. The centerline gauge marker has nothing to do with where your "normal" t-stat reading should be.
Another Mopar vehicle I own "had" a stock 210 t-stat, which would of read right of center on the temp gauge, which was it's normal operating temp.
Old Nov 26, 2012 | 06:51 AM
gtivr6's Avatar
gtivr6
alright Ill take your word for it. sounds good
