Question about transfer case
Old Dec 6, 2012 | 07:56 PM
Kscha41's Avatar
Kscha41
Default Question about transfer case
Hi everyone, Im normally over on the 3rd gen because I own an 04 but now Im looking at a 4th gen. I found an 11' that I like and I have a question on the transfer case. It has the auto 4wd plus the rest so I know that it is a Borg Warner 44-44. But my question is when I was test driving the truck, I tried the 4wd and tried turning in a parking lot and nothing happened. We tried in auto 4wd, 4 hi and 4 low. I asked the dealer why it doesn't lock when turning tight and he told me that this is one of the new features on the case. He said it started in 2010. He also said that it will lock as soon as it senses it slipping. Thats when I told him, isn't that what the auto 4wd is for, and 4wd should be locked all the time, because if not, auto 4wd and 4wd would be the same. Is this info correct from the salesmen or is there something wrong with it? Should it be locked when its is 4wd? He said they had there mechanic look at it and test it and check for codes and he said everything works the way it is surpose to. I've been looking online for any info on this and I can't find any. Thanks for your help
Old Dec 6, 2012 | 09:41 PM
PostalTwo's Avatar
PostalTwo
its my understanding that 4 auto locks only when its needed and 4 lock is in all the time. i personally dont have the auto system but when im in 4 lock i can deff tell its in when turning to steering lock it loads down but not as much as other vehicles with 4wd that i have owned
Old Dec 6, 2012 | 10:58 PM
BigBlueEdge's Avatar
BigBlueEdge
On my 2010 Sport, which does not have Auto 4WD - only 4 Lock and 4 Low - it WILL bind up on dry pavement when turning. I would think that on the one you drove 4 Auto should not but 4 hi and low definitely should.
Rob
Old Dec 7, 2012 | 10:16 AM
DodgeCares's Avatar
DodgeCares
Kscha,
Below is from the manual as to how it is supposed to operate.
Electronically Shifted Transfer Case
(Five-Position Switch) – If Equipped
This is an electronic shift transfer case and is operated by
the 4WD Control Switch (Transfer Case Switch), which is
located on the instrument panel.
This electronically shifted transfer case provides five
mode positions:
• Two-wheel drive high range (2WD)
• Four-wheel drive automatic range (4WD AUTO)
• Four-wheel drive lock range (4WD LOCK)
• Four-wheel drive low range (4WD LOW)
• Neutral (NEUTRAL)
This electronically shifted transfer case is designed to be
driven in the two–wheel drive position (2WD) or fourwheel
drive position (4WD AUTO) for normal street and
highway conditions on dry hard surfaced roads). Driving
the vehicle in 2WD will have greater fuel economy
benefits as the front axle is not engaged in 2WD.
For variable driving conditions, the 4WD AUTO mode
can be used. In this mode, the front axle is engaged, but
the vehicle’s power is sent to the rear wheels. Four-wheel
drive will be automatically engaged when the vehicle
senses a loss of traction. Because the front axle is engaged,
this mode will result in lower fuel economy than
the 2WD mode.
When additional traction is required, the transfer case
4WD LOCK and 4WD LOW positions can be used to lock
the front and rear driveshafts together forcing the front
and rear wheels to rotate at the same speed. This is
accomplished by rotating the 4WD Control Switch to the
desired position. Refer to “Shifting Procedure” for specific
shifting instructions. The 4WD LOCK and 4WD
LOW positions are designed for loose, slippery road
surfaces only. Driving in the 4WD LOCK and 4WD LOW
positions on dry hard surfaced roads may cause increased
tire wear and damage to the driveline components.
NOTE: The transfer case NEUTRAL position is selected
by depressing the recessed button located on the lower
left hand corner of the 4WD Control Switch. The transfer
case NEUTRAL position is to be used for recreational
towing only. Refer to “Recreational Towing” in “Starting
and Operating” for further information.
Transfer Case Position Indicator Lights
The Transfer Case Position Indicator Lights (4WD,
4LOW, and 4WD AUTO) are located on the instrument
cluster and indicate the current and desired transfer case
selection. When you select a different transfer case position,
the position indicator lights will do the following:
If All Shift Conditions Are Met:
1. The current position indicator light will turn OFF.
2. The selected position indicator light will flash until the
transfer case completes the shift.
3. When the shift is complete, the indicator light for the
selected position will stop flashing and remain ON.
One Or More Shift Conditions Are Not Met:
1. The indicator light for the current position will remain
ON.
2. The newly selected position indicator light will continue
to flash.
3. The transfer case will not shift.
NOTE: Before retrying a selection, make certain that all
the necessary requirements for selecting a new transfer
case position have been met. To retry the selection, turn
the control **** back to the current position, wait five
seconds, and retry selection. To find the shift requirements,
refer to the Shifting Procedure for your transfer
case, located in this section of the owner’s manual.
The “SVC 4WD Warning Light” monitors the electronic
shift four-wheel drive system. If this light remains on
after engine start up or illuminates during driving, it
means that the four-wheel drive system is not functioning
properly and that service is required.
NOTE: Do not attempt to make a shift while only the
front or rear wheels are spinning. This could cause
damage to driveline components.
When operating your vehicle in 4WD LOW, the engine
speed is approximately three times that of the 2WD, 4WD
AUTO or 4WD LOCK positions at a given road speed.
Take care not to overspeed the engine and do not exceed
25 mph (40 km/h).
Proper operation of four-wheel drive vehicles depends
on tires of equal size, type and circumference on each
wheel. Any difference in tire size can cause damage to the
transfer case.
Because four-wheel drive provides improved traction,
there is a tendency to exceed safe turning and stopping
speeds. Do not go faster than road conditions permit.
For additional information on the appropriate use of each
transfer case mode position, see the information below:
2WD
Rear-Wheel Drive High Range - This range is for normal
street and highway driving on dry hard surfaced roads.
4WD AUTO
Four-Wheel Drive Auto Range - This range sends power
to the rear wheels. The four–wheel drive system will be
automatically engaged when the vehicle senses a loss of
traction. Additional traction for varying road conditions.
4WD LOCK
Four-Wheel Drive Lock Range - This range locks the front
and rear driveshafts together forcing the front and rear
wheels to rotate at the same speed. Additional traction
for loose, slippery road surfaces only.
4WD LOW
Four-Wheel Drive Low Range - This range provides low
speed four-wheel drive. Locks the front and rear driveshafts
together forcing the front and rear wheels to rotate
at the same speed. Additional traction and maximum
pulling power for loose, slippery road surfaces only. Do
not exceed 25 mph (40 km/h).
N
Neutral - This range disengages both the front and rear
driveshafts from the powertrain. To be used for flat
towing behind another vehicle. Refer to “Recreational
Towing” in “Starting and Operating” for further
information.
Shifting Procedure
NOTE:
• If any of the requirements to select a new transfer case
position have not been met, the transfer case will not
shift. The position indicator light for the previous
position will remain ON, and the newly selected
position indicator light will continue to flash until all
the requirements for the selected position have been
met. To retry a shift: return the control **** back to the
original position, make certain all shift requirements
have been met, wait five seconds and try the shift
again.
• If all the requirements to select a new transfer case
position have been met, the current position indicator
light will turn OFF, the selected position indicator light
will flash until the transfer case completes the shift.
When the shift is complete, the position indicator light
for the selected position will stop flashing and remain
ON.
2WD ⇔ 4WD AUTO or 4WD LOCK
Rotate the 4WD Control Switch to the desired position.
Shifts between 2WD and 4WD AUTO and 4WD LOCK
can be done with the vehicle stopped or in motion. With
the vehicle in motion, the transfer case will engage/
disengage faster if you momentarily release the accelerator
pedal after turning the control switch. If the vehicle is
stopped, the ignition switch must be in the ON position
with the engine either running or OFF. This shift cannot
be completed if the ignition switch is in the ACC position.
2WD or 4WD AUTO or 4WD LOCK ⇔ 4WD LOW
NOTE: When shifting into or out of 4WD LOW some
gear noise may be heard. This noise is normal and is not
detrimental to the vehicle or occupants.
Shifting can be performed with the vehicle rolling 2 to
3 mph (3 to 5 km/h) or completely stopped. Use either of
the following procedures:
Preferred Procedure
1. With the engine running, slow the vehicle to 2 to
3 mph (3 to 5 km/h).
2. Shift the transmission into NEUTRAL.
3. While still rolling, rotate the transfer case control
switch to the desired position.
4. After the desired position indicator light is ON (not
flashing), shift the transmission back into gear.
Alternate Procedure
1. Bring the vehicle to complete stop.
2. With the ignition switch in the ON position and the
engine either OFF or running, shift the transmission into
NEUTRAL.
3. Rotate the transfer case control switch to the desired
position.
NOTE: If Steps 1 or 2 of either the Preferred or Alternate
Procedure are not satisfied prior to attempting the shift or
if they no longer are being met while the shift attempt is
in process, the desired position indicator light will flash
continuously while the original position indicator light is
ON, until all requirements have been met.
Old Dec 7, 2012 | 09:57 PM
Kscha41's Avatar
Kscha41
Ok thanks everyone for your help. Today I also deceided to call some dealers to find out what they say. Well I ended up calling three dealers and nobody knew anything. Finally the last dealer deceided to call Chrysler and see what they say. Well thay said that starting in 2011 a new transfer case was put out. The new one acts just like the way the one I test drove. I guess its called active transfer case or something like that. It reduces wear and tear and drag by allowing it to slip when turning tight on dry pavements. I guess the diffenece between auto 4wd and 4wd is auto 4wd alows for it to slip a little more before kicking in the 4wd and 4wd will kick in the very time it senses it slip. I dont know, all these seems confusing compared to my old shift on the floor.
Old Dec 10, 2012 | 09:10 AM
DodgeCares's Avatar
DodgeCares
All the different systems for each particular model year can be found in the manual link below. Just input the year and model. The manual will lists all systems for any particular year and how they are supposed to operate.
http://www.ramtrucks.com/en/owners/manuals/
Old Dec 11, 2012 | 05:52 PM
Kscha41's Avatar
Kscha41
Thanks a lot for your help. I bought the truck last night so now I'm an owner of an 11 and not an 04 anymore.
Old Dec 12, 2012 | 07:42 AM
DodgeCares's Avatar
DodgeCares
Congrats on your truck purchase!!! If you want a build sheet PM me the Vin and I will get you one right out.
Old Dec 12, 2012 | 08:31 PM
Kscha41's Avatar
Kscha41
Thanks, Pm sent
Old Dec 13, 2012 | 10:15 AM
DodgeCares's Avatar
DodgeCares
Thanks, Pm sent
I sent the build sheet. If you need anything else let me know.
