Mufflex retrofit installed and have a ???
Old Jan 13, 2013 | 08:05 PM
HEMI07's Avatar
HEMI07
Default Mufflex retrofit installed and have a ???
Has anyone installed the mufflex 14" retrofit and noticed the exhaust tips don't line up exactly where they originally were? The seem to stick out slightly further and sit a little lower than they originally need
Old Jan 14, 2013 | 01:08 AM
kddsRam's Avatar
kddsRam
I have the same setup and thought they were pretty close. Can you loosen up the 3 clamps, reposition the tails, and have someone hold them while you retighten the clamps?
Old Jan 14, 2013 | 12:53 PM
kddsRam's Avatar
kddsRam
I looked at mine this morning and the tips are about 1 inch from the top of the cutouts and flush with farthest part. So the bottom of the tips are out further since the bumper curves in across the bottom.
Old Jan 14, 2013 | 01:36 PM
HEMI07's Avatar
HEMI07
If I were to loosen the clamps and rotate the tailpipes then they wouldn't be centered in the cut-outs anymore. All the pipes are are in as far as they can go and are hitting the alignment tabs on the factory pipes. It's not really that far off...just notice a little more of a gap than i did before.
Has anyone bought the 5" stainless tips that Mufflex sells for the factory dual exhaust?
Old Jan 14, 2013 | 08:38 PM
RAMULAK's Avatar
RAMULAK
Mine too. Also watch out because those band clamps loosen up. I had to take those off and use regular clamps on the pipe that goes from the muffler to the converter. The muffler almost fell off it was so loose.
Old Jan 16, 2013 | 04:22 PM
HEMI07's Avatar
HEMI07
I will keep an eye on the clamps...I put them on with my 1/2" impact so they are very tight!
Old Jan 16, 2013 | 07:58 PM
RAMULAK's Avatar
RAMULAK
Yeah I did too. Band clamps will not compress onto another round pipe as tightly, the same way the old style clamps do by crimping the two pipes together.
Old Jan 17, 2013 | 02:01 AM
kddsRam's Avatar
kddsRam
My inlet and outlet pipes came with only one slit in them. I just cut another slit on the opposite side of inlet and outlet pipes of where mufflex ones are. About the width of two jig saw blades. Then put the same clamps back on flush with the ends of the inlet and outlets. Barely had to crank them down with just a half inch ratchet and they pinched tight. No leaks or issues for three years now.
Old Jan 18, 2013 | 12:37 PM
RAMULAK's Avatar
RAMULAK
Oh sure.....Now you gibe me that tip.....
Old Jan 18, 2013 | 03:22 PM
dirtydog's Avatar
dirtydog
Moderate User
