Old Aug 17, 2015, 12:34 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine Problem Guides
Print Wikipost
2012 Dodge Ram 1500 HEMI Engine Knock in the U.S.
Old Jan 20, 2013 | 02:26 PM
graywolf069's Avatar
graywolf069
Default 2012 Dodge Ram 1500 HEMI Engine Knock in the U.S.
I have a 2012 Dodge 1500Ram HEMI Engine Knock at warm up only. Dealer is tells me it's a normal thing. He show me two that did the samething it's only on a cold start.
Old Jan 21, 2013 | 08:54 AM
hounddogg's Avatar
hounddogg
Ok. He's right. Most all engines make noise of some sort more so on cold start. My hemi makes less noise then the 6.2 in my corvette and less then the 6.0 in my previous corvette. My 4.6 in my 2010 Merc. is quieter then the hemi and 6.2 BUT you can hear the timing chain(I think) for a little bit, worse the colder it is. My 1998 318 Magnum was pretty quiet. (old caste iron block and heads)Now if you want to listen to noises,pull it up next to a wall hot or do a cold start and listen intently. You'll hear a lot going on. I also think what these engine blocks/heads are made of and thickness has some to do with noise transfer. (318 Magnum was quietest of the bunch)
Old Jan 21, 2013 | 12:10 PM
oldjeep's Avatar
oldjeep
Sounds like Hemi Tick. Some say that the never hear it, but every hemi I've heard does the same thing on cold startup.
Old Jan 21, 2013 | 12:15 PM
Atomic Dog's Avatar
Atomic Dog
My 5.7 is super quiet UNLESS I stop for about 20 minutes. When the hot engine sits, it had a horrid lifter tap. Takes a good 10 minutes of driving for it to work itself out.
When I was young we would say the lifter was pumped up. Though I have no idea what it really is.
Old Jan 21, 2013 | 01:25 PM
hounddogg's Avatar
hounddogg
Usually the oil filter causes this. Try a Pure 1,Mobil,factory etc. If it still does it you have a 'issue' I don't know what a Hemi 'tic' sounds like. Mine just sounds like a cold V8 and you can hear stuff. Noting unusual to me.
Old Jan 21, 2013 | 02:05 PM
mezerr's Avatar
mezerr
How come every time someone says they have an engine KNOCK, people says it's the Hemi TICK?
Old Jan 21, 2013 | 06:20 PM
oldjeep's Avatar
oldjeep
Because most folks don't have a clue what a KNOCK actually sounds like. And if the engine is actually knocking, it usually tosses a part through the pan in a short period of time.
Old Jan 21, 2013 | 06:39 PM
hounddogg's Avatar
hounddogg
What he just said.
Old Jan 21, 2013 | 07:00 PM
mezerr's Avatar
mezerr
Really? I guess I just assumed that when people heard a TICKING noise, they would call it a tick, and when they heard a KNOCKING noise they would call it a KNOCK.
I bet you $20 bucks if the OP took a video it would be a knock.
Old Jan 21, 2013 | 07:04 PM
oldjeep's Avatar
oldjeep
I'd take that bet, because engines do not just knock when they are cold. If it is knocking, its doing it full time. Knock is caused by failing parts that are out of spec - worn rod bearings, loose rod bolts or bad wrist pins. A cold noise is not a knock - it is lifter noise, or sometimes just detonation. I'm sure you've got 20+ years of engine building to back up your thoughts, so lets hear them
