Rear Tail Light not flashing
Old Feb 22, 2013 | 07:27 PM
JK Rupprecht's Avatar
JK Rupprecht
Default Rear Tail Light not flashing
Left-rear tail light in my 09 Ram 1500 won't flash when I use the turn signal, but illuminates just fine when I apply the brakes.
When I use the turn signal, the left-turn arrow on the dashboard blinks double-time like I have a burned out light, but obviously it's not burned out since it comes on fine with the brakes. I'm guessing I can't fix this just be replacing the bulb?
Old Feb 23, 2013 | 08:01 AM
LU229's Avatar
LU229
Try another bulb anyway, weirder things have happened. And its a cheap fix if thats all it is. Also check the front turn signal to MAKE SURE its working.
Old Feb 23, 2013 | 03:33 PM
JK Rupprecht
Thanks for the response. This turned out to be a simple fix, with a $6, dual-element bulb. One of the elements was burned out, but not the other. That's why the brake lights worked normally, but the flashers did not.
Old Feb 25, 2013 | 10:16 AM
LU229's Avatar
LU229
And it didnt require a useless trip to the useless dealer...AMAZING ain`t it...lol.
