2013 Speaker Replacement
Old May 5, 2013 | 06:06 PM
t5000's Avatar
t5000
Default 2013 Speaker Replacement
Does anyone on here have instructions on how to remove/install new speakers on a 2013? I've seen write ups on earlier models but even Crutchfield doesn't have anything yet on the 2013 model Ram. Thanks
Old May 5, 2013 | 07:26 PM
t5000's Avatar
t5000
Anyone?
Old May 6, 2013 | 08:40 AM
DodgeCares's Avatar
DodgeCares
What speakers? What cab configuration do you have? 1500?
Old May 7, 2013 | 12:36 PM
t5000's Avatar
t5000
I have to update my profile. I have a 2013 1500 Crew Cab 4x4
Old May 7, 2013 | 01:12 PM
DodgeCares's Avatar
DodgeCares
FRONT DOOR SPEAKER
  1. Disconnect and isolate the negative battery cable.
  2. Remove the front door trim panel
3.Remove the speaker mounting fasteners.
4.Disconnect the electrical connector and remove the speaker
INSTRUMENT PANEL CENTER SPEAKER
  2. Remove the center instrument panel speaker grill.
  1. Remove the speaker mounting fasteners.
  2. Disconnect the electrical connector and remove the speaker .
INSTRUMENT PANEL END SPEAKER
  1. Disconnect and isolate the battery negative cable.
  2. Remove the instrument panel speaker grill.
  2. Disconnect the electrical connector and remove the speaker.
REAR CAB SIDE SPEAKER
  2. Remove the B-pillar lower trim .
  3. Remove the speaker mounting fasteners.
  4. Disconnect the electrical connector and remove the speaker.
REAR DOOR SPEAKER
  2. Remove the rear door trim panel .
  1. Remove the speaker mounting fasteners .
SUBWOOFER - STAN/QUAD/CREW CAB
  1. Remove the mounting fasteners to the subwoofer housing.
  2. Disconnect the electrical connector.
SUBWOOFER - MEGA CAB
  2. Raise right rear seat to access the subwoofer.
  1. Remove the mounting fasteners.
  2. Disconnect the electrical connector and remove the subwoofer.
HEADLINER MOUNTED SPEAKER
  2. Using a trim stick, remove the speaker cover from the headliner .
  3. Remove the two retainers holding the speaker into the headliner .
