Warranty done in a month what to check
Old Jun 27, 2013 | 12:22 AM
706jim's Avatar
706jim
Default Warranty done in a month what to check
Two more payments and one more month of warranty left on my 2010 QC. Any suggestions as to what to look for during its next dealer inspection that I might still be able to get fixed?
Old Jun 27, 2013 | 12:55 AM
LU229's Avatar
LU229
Goes without saying really, what ever is covered under warranty are the things i would consider looking at. Most of what i`ve ever seen go bad is the TIPM, the climate control for the heat/ac unit (the digital ones). Everything else is usually ok. Check your headliner for water stains... usually see water stains at the right and left sides at the rear of the headliner... they did have a 3rd brake light lense sealing issue. Rain water would get inside the cab due to a ElCheapo gasket they used on the 3rd brk/light housing. I fixed my own by sealing it up with a light film of silicone sealer around the base of the 3rd brk/light lense, put it back on the truck, not leaked since. To get the stains out, i used a small hand held steamer with oxy-clean, stains came right out nicely. (something the dealership could never seem to fix after 5 trips back for the same problem)
