Camper Towing
Old Jul 18, 2013 | 11:49 PM
rbrumm's Avatar
rbrumm
My truck pulls my 7500 lb trailer very well. Just use the equalizer and swaybars.
Old Jul 19, 2013 | 09:54 AM
jhardin80's Avatar
jhardin80
Originally Posted by HEMI_ROM
Thank you for the replay, good info. I also live in the Springs and know that route very well. I am rated to 9200LBs towing capacity without even using my tuner. I also had to up the preload on my WDH 2 notches after going from my 04 RAM to the 09, other than that the weight is NO problem I can still do 65 up the HWY 24 grade all the way into Divide with no problems.. EVERY time I get held up going up these 10,000 foot passes it is because I am stuck behind some F-150 with the 5.4L huffing and puffing and doing like 20MPH. I think I will be fine then going 6 feet longer and about 1100lbs heavier. Power is not an issue on the new RAMS, I just don't want to be using up all my rated tow capacity - as you know these mountains here will tear up the unprepared and underpowered. In the summer I am sure you have seen the grade on I-70 near the Eisenhower tunnel looks like a battlefield with all the broken down steaming vehicles along the shoulder. If you can tow up here, you can tow anywhere. Thanks again, see ya on the roads
Yes power is definitely not an issue with these trucks, the only thing I am worried about is the transmission heating up. When we went on our trip to ouray, my transmission topped out at about 225 at one point. I was getting a little nervous but it never went any higher and that temp was just for a mile or two. If I stay in it going up 24 I can do 65 if I want but then my tranny starts to get warm so I am just one of those that cruises at 40 all the way and my tranny stays nice and cool. take care
Old Jul 19, 2013 | 01:13 PM
BigBlueEdge's Avatar
BigBlueEdge
That's about what I experienced when pulling about 8500# through the mountains. It was up to around 220* for short uphill stretches, but as an average it was not consistently that high. From what I've read, if you're just peaking for short periods at those temps it is not nearly as bad as if you were running for hours at those levels.
Rob
Old Jul 19, 2013 | 03:37 PM
HEMI_ROM's Avatar
HEMI_ROM
Rob
Those 3.92's really help don't they. For *brief* periods you should be OK with the 220* temps - the only thing that suffered was your transmission fluid. It's my understanding that the higher transmission temps affect the transmission fluid first, its useful life is diminished. I would change out that fluid as soon as practicable. I am wondering, for those of us who already have the factory tow package, is there is any further aftermarrket Transmission cooling we can set up?
Old Jul 22, 2013 | 03:36 PM
jhardin80's Avatar
jhardin80
From my understanding there really isn't any because if you cool it too much at regular speeds then it won't get to the optimal temp. If you are towing everyday and getting around 220* then I guess you could put on another or bigger cooler, but since mine is a daily driver and only tow a little during the year I will just change the fluid sooner each time. I'm no pro though so if you hear of something then let me know
Old Jul 22, 2013 | 08:41 PM
Dodgeboy77's Avatar
Dodgeboy77
change your trans fluid to amsoil, it will run cooler it (and the fluid) will last longer, and it pours to -54 so you are always protected. i read a magazine that dyno'ed a v8 dakota then changed to synthetics and no other upgrades and got 15hp on the dyno.
Old Aug 10, 2013 | 06:57 AM
kells81's Avatar
kells81
New Member
My TT has the weight sticker on it from just prior to leaving the dealer with it at 6415, This was the recent weight of it. Now its probably 7,000#
Towing it with a 2012 Laramie Longhorn with 3.92 (maybe wrong but 3.9 something) gearing. I was worried I did not bring enough truck
Anyhow about midway on our trip yesterday I started getting the shutter that your describing. I did notice it was when I was stopping at traffic lights on a downhill slope though.
Still need to finish working the bugs out of the WD adjustment but I definitely have enough truck..
