trailer plug
Old Jul 20, 2013 | 08:33 PM
edwinger34's Avatar
edwinger34
Default trailer plug
Hello all I have 2012 dodge ram the trailer plug on the back, the prong that power the tail light don't have power on it the rest of the prongs work ok and the tail light on the truck work ok does anyone have any idea what to look for.
Ed H.
Old Jul 21, 2013 | 05:40 PM
capsfloyd's Avatar
capsfloyd
If you have already put a tester on this on copper pin
Are you talking about the 4 flat or the round 7 pin ?
Old Jul 21, 2013 | 08:02 PM
edwinger34's Avatar
edwinger34
Mine has both the 4 and the 7 the tail light plug is dead on both.
Ed H
Old Jul 21, 2013 | 09:07 PM
Pedro Dog's Avatar
Pedro Dog
There is a link on the DIY section for the wiring diagrams for your truck. Look them up.
Old Jul 21, 2013 | 09:12 PM
BigBlueEdge's Avatar
BigBlueEdge
You've tested with a test light or multimeter? I wouldn't rely on the trailer as a valid test case. It's more likely the trailer's wiring is messed up than the truck's. If you have tested that way, then I guess I'd start looking for a fuse related to it. With everything controlled by computer these days though, it could be harder to track down than that...
Rob
Old Jul 22, 2013 | 11:32 AM
edwinger34's Avatar
edwinger34
Yes I tested with a test light I didn't trusted the trailer wiring I called the dealer today take it Fri let them worry about it. Thank all anyway.
Ed H.
Old Jul 23, 2013 | 11:14 AM
DodgeCACares's Avatar
DodgeCACares
Ed,
Keep us posted on the outcome. If you have any additional inquiries please feel free to PM me!
Welcome to the Dodge Forum.
Old Jul 24, 2013 | 05:53 PM
edwinger34's Avatar
edwinger34
I am going to the dealer tomorrow I will let you know the outcome.
Ed H.
Old Jul 27, 2013 | 06:52 PM
edwinger34's Avatar
edwinger34
Well it was a fuse it was one the square ones not the small flat one they was the only one I check. I had never had any dealing with the square ones so I learn something after all see you all later.
Ed.
Old Oct 20, 2014 | 04:29 PM
gonesailing@swbell.net's Avatar
Default Trailer Plug
Ed, Thanks for posting what the problem was. I have a 2012 2500 diesel. I lost power to the trailer running lights one night and have yet been able to find the problem on my own. I easily found a wire on the trailer had rubbed through and burned a bit of the insulation. I have bought a chiltons which was worthless in helping and have read the the fuse diagram on the bottom of the the TIPM several times but I never checked any of the big fuses, just looked at them. The truck is fine, it is just the running lights for the trailer, both factory plugs like you described. I will go check and then finish this post.
You're the man ED. Fuse J14, one of the big ones. It's marked park lamp, main and trlr. The truck lights are fine but I found it. Thanks for the reply that put me in the correct direction.
