question on R/T mods for my express
Old Aug 15, 2013 | 01:09 AM
jgladhill3's Avatar
jgladhill3
Default question on R/T mods for my express
was reading an article about the R/T 1500, and from what I gathered from performance perspective, the R/T nets you a high stall torque converter and 4.10 gear.....I found a site that sells 4.10 gears, and since I work for a dealership, can probably get much cheaper through our parts dept....but does the TC make much difference? pricey? worth the $$ to get? all opinions/info are appreciated, thanks!
Old Aug 15, 2013 | 06:12 AM
War Horse's Avatar
War Horse
The 4.10s are a doable mod. If you're coming from the 3.55s or 3.21s you'll also need the LSD unit, which the 3.92s and 4.10s come with. As for the TC, I have no idea, I've never rode in an R/T to really know. Don't forget about the R/T weight advantage as well. It being a single cab short bed reduces the weight some to help give a little extra oomph.
Old Aug 15, 2013 | 08:26 AM
jgladhill3's Avatar
jgladhill3
appreciate the feedback, and my express is also a single cab
Old Aug 15, 2013 | 09:00 AM
LU229's Avatar
LU229
The TC isnt worth doing in my opinion... not enough of a gain vs dollars spent to do it... also a higher stall converter meens more trans slippage.
Old Aug 15, 2013 | 09:19 PM
POWER SEDAN's Avatar
POWER SEDAN
Agreed with Lu, you're going to need more aggresive support mods before a torque convertor will be a beneficial investment.
I had a 2,800 TC on my Charger, but that was after building the 345 with stage II mods. My Charger was non-aspirated, so a TC was more beneficial at the track with launching near my "productive" power RPM range.
Old Aug 16, 2013 | 07:26 AM
jgladhill3's Avatar
jgladhill3
thanks for the input guys
