Ignition Node Question
Old Sep 16, 2013 | 07:25 PM
MadOTC's Avatar
MadOTC
Default Ignition Node Question
I have a 2009 Ram 1500 V6, and I believe as of today I am the proud owner of a faulty Ignition Node. I went to start my truck at lunch today, the dash flickered a few times then everything just went dark. I tried to turn it back off and pull the key out, and it seemed to be stuck. I eventually got the key out, but i'm still without a working truck. Any way to fix this without being out $400 for a new module and new keys?? Also, I see a recall for this part on 2010 models, but not 2009. Does anyone know if this was a recalled part for 2009 model trucks also? Thanks for your help.
Old Sep 16, 2013 | 08:55 PM
Owensue's Avatar
Owensue
Have you tried your other fob? It may not be the module just your one fob.
Some people have had luck doing a battery disconnect and trying again.
Old Sep 16, 2013 | 10:12 PM
MadOTC's Avatar
MadOTC
I'm pretty sure the module is toast. If you push the key in all the way it gets stuck, and is very hard to pull out. I tried it with my extra key, and it did the same thing. What's the lease expensive way to make this work again?
Old Sep 17, 2013 | 09:35 AM
LU229's Avatar
LU229
Sounds like you`ll have to bite it for a new ignition... no other way around it.
Maybe call chrysler and see if they`ll warranty it for you (???)
Old Sep 17, 2013 | 10:59 AM
MadOTC's Avatar
MadOTC
I think I may end up having to buy a used one online, at least as a temporary solution. Don't have a couple hundred bills to drop on a new one right now. It looks like there was a recall on the 2010 year, but not on 2009. Guess I should call the dealership just to make sure. Every day i wish I would have kept my 2005, instead of buying this truck. It has been nothing but trouble right from the beginning.
