camshaft position actuator solenoid
Old Oct 13, 2013 | 11:16 PM
mtlmlshatrps03's Avatar
mtlmlshatrps03
Default camshaft position actuator solenoid
check engine light came on p0013
apparently the camshaft position actuator solenoid needs to be replaced, but im having a hard time finding it online.
ive googled it, searched on this site, and went to a couple auto part stores and they keep showing a camshaft position sensor (the one down by the tranny), but that one is fine
a mechanic friend of mine told me the camshaft position actuator solenoid is located towards the top of the engine and theres more than one
can anyone help me out?
Old Oct 14, 2013 | 12:48 AM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
No year and no engine size makes it pretty difficult to help you.
Old Oct 14, 2013 | 11:53 AM
mtlmlshatrps03
oh sorry i thought the 4th gens used the same parts
but i have 2009 1500 5.7 hemi 4x4
Old Oct 14, 2013 | 12:05 PM
TNtech's Avatar
TNtech
2013 3.6 Pentastar has those too which is why I was asking. 2 on each side.
Yours has one in the center. It's not a sensor, it a variable valve timing actuator, or solenoid. The solenoid directs oil to the phaser (camshaft sprocket). It's under the intake manifold.
Old Oct 14, 2013 | 04:31 PM
LU229's Avatar
LU229
Why do you think it failed...??? What oil and filter are you running in this engine...?
Old Oct 14, 2013 | 05:12 PM
mtlmlshatrps03
yeah i figured it wasnt a sensor, but every time i went to a parts store, thats what they showed.
any idea on how to find one of those? part number? i havent had any luck finding one
Old Oct 14, 2013 | 05:17 PM
mtlmlshatrps03
oil changes have been through the dealership so im assuming they put what was recommended. i just bought it and service records say it was all changed out last month
the check engine code read p0013. i looked it up and it says camshaft position actuator solenoid fault, cmp actuator open or short circuit
i know it can probably be the wiring, but im just gonna replace it then take it down for diagnostics
Old Oct 14, 2013 | 05:59 PM
LU229's Avatar
LU229
Are you having any drivability issues...? Rumor has it that these are a problem in only the 09 hemi trucks. I think they changed them before the 10`s got out on the market. Dont hold me to that statement, i`m not positive on that particular issue with these trucks. Just going by what others have told me here in the local hemi truck scene.
Old Oct 14, 2013 | 06:30 PM
mtlmlshatrps03
are there any noticeable issues?? none whats so ever. theres some noises and vibration but a mechanic said that is just an exhaust leak and i might need to check the engine mounts for new bushings
but the mechanic also said the truck could be running alot better. i have a 96 toyota that was my daily driver for years, so driving the ram now is a HUGE difference, which is why i cant even tell that its not running at its full potential
Old Oct 14, 2013 | 06:51 PM
oldjeep's Avatar
oldjeep
Are you the original owner? I would think that this item would be covered under the lifetime powertrain.
