Hank
Old Nov 2, 2013 | 02:52 PM
hank's Avatar
hank
Default Hank
Hello from Okla.
Old Nov 2, 2013 | 03:01 PM
hank's Avatar
hank
Default 2010 laramie
Confused about transfer case. The plate on the transfer states NP246D but the owners manual says NVG246. Are these the same cases? I'm trying to find the proper fluid to use. Anyone else have this issue?
Old Nov 2, 2013 | 04:14 PM
Yep, same case. New Process became New Venture Gear (or verse visa...) not so very long ago.
What ya drivin'?
Old Nov 2, 2013 | 10:48 PM
Welcome to DF Hank. Please add some info about what vehicle you are referring to so we can better assist.
Old Nov 3, 2013 | 11:42 AM
hank's Avatar
hank
Default 2010 Laramie
What ya drivin'?
2010 Laramie. Does that transfer use the special fluid instead of the regular ATF 4 transmission fluid. I have 50,000 on the truck, should I even worry about changing it now?
Old Nov 3, 2013 | 03:33 PM
I will move this to the correct section so you can get some help.
Old Nov 5, 2013 | 10:51 AM
hank's Avatar
hank
Good morning j keaton, you moved my post to another section and I can't find it. Was it non-tech, general discussion, etc.
Thanks Hank
Old Nov 5, 2013 | 10:57 AM
oldjeep's Avatar
oldjeep
There is a book in the glove compartment that will tell you what sort of fluid your transfercase needs. If it is missing then you can download one from the RAM site:
http://www.ramtrucks.com/en/owners/manuals/
