Heater problem RAM 2009
Old Nov 11, 2013 | 04:33 AM
rokla001's Avatar
rokla001
Default Heater problem RAM 2009
Since this morning I don't get any hot air in my car. It makes no difference where I put the switch, the air stays cold. I'm a car-mechanic teacher myself and I haven't looked into it yet, but maybe there's a simple explanation for this problem???
Old Nov 12, 2013 | 07:23 PM
jasonw's Avatar
jasonw
Site Moderator
Welcome to DF. For future reference:
https://dodgeforum.com/forum/dodge-r...ead-first.html
I will move you this time.
Old Nov 13, 2013 | 11:48 PM
Mikeyyy816's Avatar
Mikeyyy816
I pulled my radio the other day to take a look at the sub dash....when i was putting the plugs(4x4, ac, temp control, mfs) and cover back on..didn't notice until the next day but the heat didn't work..pulled it back off...took a look everything was plugged in correctly so for the hell of it i unplugged it and plugged it back and in and it was working again. worth a shot...
Old Nov 14, 2013 | 09:34 AM
LU229's Avatar
LU229
Contact your local dealership, i believe ther was a recall on this issue.
If your dealer is no help, call chrysler directly.
Old Nov 15, 2013 | 01:37 PM
LVRR's Avatar
LVRR
If they try to charge you since it is a 2009 you may want to check the motors that drive the system. I am not sure which motor controls the temperature but the one I did is for the position of the air exiting, the blend door motor.
Two other motors are in the system, one you can see in the upper left corner of the last few pictures and one in the glove box area. Not sure which is for the temperature control, you'll have to test for that. If it is the motor it is easy enough to replace and not that expensive compared to what the dealer may charge you.
https://dodgeforum.com/forum/3030104-post4.html
