Ready lift level kit plus timbren stops in the rear- will this work?
Old Nov 26, 2013 | 03:27 PM
blackfox's Avatar
blackfox
Default Ready lift level kit plus timbren stops in the rear- will this work?
Hello all,
I have a 2013 1500 Big Horn with 3:92 gears. I tow a 6500lb travel trailer with good w/d. When hooked up it sits fairly level. I prefer my trucks to sit level but am not willing to sacrifice safety. I am looking at leveling the front but don't want to be high in the sky when hooked up. Any ideas if adding a set of Timbren stops in the rear will help keep the truck sitting level when hooked up? Thanks for any comments.
Old Nov 26, 2013 | 09:34 PM
ryans590's Avatar
ryans590
I went with air bags in the rear instead of the timberns because they're adjustable. When I hook onto my 7500# trailer the air bags and equalizer hitch still keep it level and ive got the rancho leveling kit upfront.
Old Nov 27, 2013 | 02:59 PM
blackfox's Avatar
blackfox
Thank you for your comments.
Old Dec 7, 2013 | 09:28 AM
mikey0469's Avatar
mikey0469
It doesn't really matter how much you're towing but the amount of weight that is on the tongue. I have the timbrens without a front leveling kit and it levels out with near 1000 lbs or so of weight in the bed, off hand estimate I would say. I could only imagine that if your front was raised another inch or two that it would be a high front, but even then, I still wouldn't consider airbags over my timbrens. Maintenance free without a chance of something going wrong.
