TPMS and E Rated Tires ?
Old Nov 30, 2013 | 08:59 AM
roadrnnr's Avatar
roadrnnr
Default TPMS and E Rated Tires ?
Thought I read on here somewhere that running the higher tire pressure with a E rated tire will make the TPMS sensor go off.
Can anybody confirm or deny this who is running a E rated tire and pressures of 65-80 psi.
I want to go with an e rated tire but don't want the hassles of the TPMS being on all the time.
Thanks,
Old Nov 30, 2013 | 10:54 AM
hattitude's Avatar
hattitude
I think it depends on how your truck is set up...
My 2500 came with E-rated tires. I also have a "light Load" switch. It allows me to run my tires at around 50psi, when I don't have a load, for a more comfortable ride. Without the "light load" switch, I would have to keep them up closer to 70-80psi or the tpms would send a "low tire pressure" message/alarm.
I don't know what happens if you put 70psi in tires that the truck expects to see only 40-50psi….?
Old Nov 30, 2013 | 11:14 AM
roadrnnr's Avatar
roadrnnr
Yeah that is what I am trying to figure out. I have a 1500, no load switch, and want a stiffer tire for pulling my boat than a P rated tire. But not if the Sensor light will be on.
Hopefully someone with a 1500 running LT tires will chime in.
Old Nov 30, 2013 | 11:21 AM
tommyexpress's Avatar
tommyexpress
Im not a tire guy but is it safe for that rim to run that much pressure? as for the sensors i think it is a low limit built into them. might be ok to run the psi higher just when towing....really i have nothing helpful to add, just thinking outloud
Old Nov 30, 2013 | 05:08 PM
hattitude's Avatar
hattitude
I just checked for a replacement TPMS sensor and found the Schrader 56029398AA, 433MHz TPMS is listed for all 2010 thru 2013 1500/2500/3500 RAM trucks both 2WD and 4WD.
http://www.tpmsdirect.com/Dodge_RAM_..._p/9398-03.htm
The fact that they all use the same sensor, leads me to believe when the EVIC sends a warning message, is a function of the EVIC. When I change the light load switch to on or off, I believe it is changing the value when the EVIC will warn me.
I'm going to guess you would be OK… but hopefully someone with a 1500 who did this will chime in…..
Old Nov 30, 2013 | 05:55 PM
oldjeep's Avatar
oldjeep
The sensors just send pressure readings, the computer in the truck decides what is too high or too low. I believe that you can have the dealer adjust the pressure at which the high low warnings come on using the starscan.
Old Dec 1, 2013 | 12:27 AM
RSDodgelover's Avatar
RSDodgelover
I have a 2012 1500 QC and like you I wanted heavier tires with stiffer sidewalls so I went with E rated snow tires for winter. Currently running 40 PSI when empty and notice a MUCH stiffer ride so will probably drop back to C rated or at the most D rated for my next tires since either should be an improvement over the OEM tires. JMO
Old Dec 1, 2013 | 01:54 PM
LVRR's Avatar
LVRR
I have also heard that these rims are not rated for that pressure. A check with Chrysler would probably be a good idea.
Old Dec 2, 2013 | 11:57 AM
4neatr's Avatar
4neatr
I don't know what sensors they used, but I just put on E rated Toyo tires on my 1500 with the lift, and the TPMS light was on for 2 days, then has figured things out I guess, because it has been off since and no issues. I am running the tires around 44psi all the way around, truck seems to like it that way. I don't need to pressure them up to the tire max, as I don't haul anything in this truck, the E rating just came with the 35's
