Blower motor replacement
Old Feb 3, 2014 | 09:35 AM
BigBlueEdge's Avatar
BigBlueEdge
Default Blower motor replacement
Has anyone replaced the blower motor in a 4th Gen RAM? Just this morning mine decided to get loud and whiny like the bearings in the motor are going bad. The noise is directly related to fan speed, so it must be the blower motor. Is this something that can be done with limited disassembly of the dash or is it something I should have the dealer do?
Thanks,
Rob
Old Feb 3, 2014 | 11:07 AM
Greasy24's Avatar
Greasy24
I haven't seen these year model truck blower motors, but I pulled mine out of mine because papers from the glove box fell down into it. Mine had like 3 screws and one connector. Your newer truck might be different?
Old Feb 3, 2014 | 11:22 AM
BigBlueEdge
Did it come out from under the dash below the glove box?
Old Feb 3, 2014 | 11:24 AM
Greasy24's Avatar
Greasy24
Yes passenger side under the glove box, mine was very easy to get too.
Old Feb 3, 2014 | 11:26 AM
BigBlueEdge
Thanks. I'll check mine to see if it is the same.
Rob
Old Feb 3, 2014 | 04:48 PM
Pedro Dog's Avatar
Pedro Dog
from the shop manual
The blower motor is located on the passenger side of the vehicle under the instrument panel. The blower motor can be removed from the vehicle without having to remove the HVAC housing assembly.
1. Disconnect and isolate the negative battery cable. 2. Disconnect the HVAC wire harness lead (3) from the blower motor (2). 3. Remove the three screws (1) that secure the blower motor to the bottom of the HVAC housing (4) and remove the blower motor.
Old Feb 3, 2014 | 04:59 PM
BigBlueEdge
Awesome info, Pedro Dog! Thanks much!
Rob
Old Feb 3, 2014 | 05:52 PM
BigBlueEdge
Wow, that is easy. Good deal!
Rob
Old Oct 22, 2015 | 01:03 AM
nobby's Avatar
nobby
Sounds easy enough. Now I just want to buy the correct part number.
Any hints?
Old Oct 22, 2015 | 09:55 AM
BigBlueEdge
The part number for my vehicle was: Part# 68048903AA
Bend over, they want $146 MSRP for it (that was in Feb 2014). Thankfully I have a source for discounted OEM parts. Even so, if I had to do it again I'd probably check RockAuto or some other source for a better deal.
ETA: The Mopar part is on Amazon for $112.
Rob
