Horrendous fuel milage (in my opinion) 2012 1500 SXT QC 5.7L 4x4
Old Feb 21, 2014 | 06:50 AM
Brynm's Avatar
Brynm
Originally Posted by LU229
Unless ther`s something bad wrong with your truck, sounds like driving habits may be your issue. Check your tire pressure, colder days you`ll lose pressure, this will cause the truck to drag and make the engine work harder. And if you`re running an aggressive treaded tire, they`ll rob you of mpg. How long are your first start-up`s... to let the truck warm up. That will suck your mpg`s away as well. Also concider winter blended fuels... that will suck your mpg`s away. Cold temp`s use more fuel. You`ve got a lot to concider during this time of year... ESPECIALLY living in CANADA...!!!
Truck still has stock tires, driving is pretty relaxed. In town it hardly ever goes above 2000 rpm before shifting, highway is at a steady 70 without cruise control because I've found I actually use more gas with cruise.
Originally Posted by TheFist
Have you tried using basic math and seeing what you get? The readout on the truck is a notorious liar and I can't imagine a phone app being all that accurate.
With the app I have I input the odometer reading, the amount of fuel used, and the cost of the fuel. It's accurate.
Old Feb 21, 2014 | 09:53 AM
NoMoreGMsForMe's Avatar
NoMoreGMsForMe
Forget about mpg , try this , count how many gas stations you pass before your next fill up , as the weather warms they will be further apart .
Old Feb 21, 2014 | 10:57 PM
Nick Ladd's Avatar
Nick Ladd
i get about 10.9-11 on regular i know alot of people out there say going to midgrade or premium doesn't affect mileage but the first time i filled with mid grade my mpg went to 11.5-11.8 and i know i haven't changed my driving habits
Old Feb 22, 2014 | 10:45 AM
BigBlueEdge's Avatar
BigBlueEdge
What octane does your engine require? The Hemi requires mid-grade (89) and if you use 87 you will very likely get worse mileage because the engine is 'de-tuning' itself to allow the 87 to burn without knocking.
Rob
Old Feb 22, 2014 | 12:07 PM
Owensue's Avatar
Owensue
Exclamation
There is a difference between a recommended fuel and required.
I agree, there is a milage increase at 89, especially in the winter months however use of 89 is not a requirement for a hemi.
Attached Thumbnails Horrendous fuel milage (in my opinion) 2012 1500 SXT QC 5.7L 4x4-image.jpg
Old Feb 22, 2014 | 12:29 PM
BigBlueEdge
"The manufacturer recommends the use of 89 octane for optimum performance."
This statement in the manual is a reference to the fact that, while the Hemi will run safely on 87 octane, it is tuned for 89 and the engine will retard timing to safely burn the 87. You will get lower gas mileage due to that if you run 87. Maybe saying that the Hemi 'requires' 89 is too rigid, but that is the normal octane the engine is designed for.
Rob
Old Feb 22, 2014 | 12:47 PM
Pedro Dog's Avatar
Pedro Dog
I sense another gas war starting up.
I haven't noticed any difference between 87 and 89, if anything I get better milage with 87. The only time 89 will help you is when you need the extra power (WOT), the rest of the time the hemi doesn't care. Hell, in higher altitudes 89 is just a waste.
Old Feb 22, 2014 | 01:16 PM
BigBlueEdge
No 'gas war'. I was just trying to help Nick with an explanation of why his MPG might have gone up when moving from 87 to 89. If something else works for you or others, great. Do what works best. This is the Internet... we're all wrong.
Old Feb 22, 2014 | 01:43 PM
Pedro Dog's Avatar
Pedro Dog
Temperature, air pressure, air density, elevation, gas quality, driving style, worn engine, carbonated valves, head winds, tail winds, tires, synthetic oil vs regular oil, etc, will affect gas milage, so comparing the diff between 87 and 89 is not easy. The energy content for a gallon of 87 and 89 are the same.
Old Feb 22, 2014 | 02:26 PM
Duso02's Avatar
Duso02
True but this is much more drastic then just different octane. I'm one where my mpg went down when switching to 89. I chalk it up to really being a "nil" difference overall for my truck and driving style. I do not plan on keeping this for 200K miles so I'm fine with 87.
Straight hwy driving, even in the winter, I get a minimum of 16 mpg so the OP getting 10-11 is huge to me. Something does seem out of the ordinary. 4wd Auto engaged all winter? I know that drives my mpg down pretty good.
