Alignment
Old Mar 3, 2014 | 11:24 AM
LU229's Avatar
LU229
Originally Posted by capsfloyd
Also on rams with 20" tires you need to rotate more often
The original OEM GoodYear HP 20inch tires themselves are the main issue for chopping... they`re JUNK.
I replaced my 20inch HP`s with BFgoodrich touring TA, no chopping in 50,000 miles, rotated every other oil change.
Some tires will chop more than others even with proper alignment specs.
Old Apr 18, 2014 | 07:30 PM
navyjetmech's Avatar
navyjetmech
Smile
Originally Posted by navyjetmech
I am having issues too. I had the dealer do the alignment when I bought it last month. I had to take it back twice. The printout says it's good but it does not travel straight. I suspect their machine is jacked. When I get home I am going to take it to an independent alignment shop.
Found out I have a radial tire pull. I cross rotated the front tires, now the steering wheel is dead center.
Old Apr 18, 2014 | 11:09 PM
Old Man with a hemi's Avatar
Old Man with a hemi
I beg to differ with this statement, as I have been riding on 20 inch wheels now for 9 years and rotation has been a normal, every 6000 miles with no problems whatsoever. Where did you hear this?
