2012 RAM 1500 wont pass emmissions!?
Old Mar 28, 2014 | 10:49 AM
Pedro Dog's Avatar
Pedro Dog
I'm always surprised at the variety of laws over different states. When I visit my daughter in tennessee, they don't recycle, and the environmental laws are pretty lax. Same for other southern states.
Old Mar 28, 2014 | 02:45 PM
dirtydog's Avatar
dirtydog
Moderate User
yeah, i dont think Florida does any kind of inspection unless you bought a car from out of state.
I've seen some pretty beat up cars that I have steered clear of while driving there. Somce scary vehicles veing driven on the road.
on the other hand...Try to own a var in the UK. You cant drive a car with rusty panels supposedly!
Old Mar 28, 2014 | 05:02 PM
Pedro Dog's Avatar
Pedro Dog
Vermont is a pretty tough state for inspections, they require the vehicle to be inspected yearly for emissions and safety. My son has had to get rid of vehicles due to the cost to comply for some of the repairs.
Vehicle Documentation:
  • Fill out vehicle work order for inspection
  • Verify registration certificate is current, accurate, and in agreement with vehicle
  • Verify insurance document is current, accurate, and in agreement with vehicle
  • Verify public VIN on vehicle dashboard and match to vehicle documentation
Safety:
  • Verify vehicle is equipped with seat belts (1964 & newer) and verify functionality
Body:
  • Check interior rearview mirror
  • Check exterior rearview mirror
  • Check windshield wipers for correct operation and condition of blades
  • Check bumpers and fenders
  • Check for protruding metal
  • Check for sun visors
Tires & Wheels:
  • Measure tires for wear
  • Check tires for cuts, snags, and cracks
  • Check tires for bumps, bulges, and knots
  • Check tire labeling for restricted usage
  • Check wheel bolts, nuts, or lugs
  • Check wheel for damage
  • Check function of TPMS system
  • Check for proper tire size
  • Check for proper inflation
  • Ensure tires do not protrude past fender walls
Steering & Suspension:
  • Check for lash or free play in steering system
  • Check power steering system for operation, fluid level, and leaks
  • Check ball joints for movement
  • Check ball joint assembly for seizure due to rust
  • If ball joint movement is detected, check tolerance with tool (use manufacturer spec's)
  • Check torsion bars or springs
  • Check tire rod ends
  • Check tie rods for seizure due to rust
  • Check condition of shock absorbers and struts
  • Check wheel bearings
  • Check axle shaft
Brakes:
  • Check for brake failure and ABS indicator lamp operation
  • Check brake system integrity
  • Check parking brake functionality
  • Check brake failure lamp
  • Check master cylinder lines and wheel brakes for signs of leakage
  • Check brake hoses for integrity, cracks, and wear
  • Road test brakes (stop within 25 feet at 20 mph)
  • Verify critical vehicle instrumentation (odometer & speedometer)
Lighting & Electrical System:
  • Perform a visual check of all lamp functionality
  • Ensure fog and driving lights illuminate with corresponding headlight beams
  • Check headlight aim
  • Check switches and functions of directional controls
  • Check defroster function
  • Check horn function
  • Check for exposed wiring for damage and poor connections
  • Check lights for cracks, leaks, or insufficient repairs
  • Check for unauthorized after-market lighting
  • Check airbag readiness light
Glass:
  • Check windshield glass for cracks, chips, and discoloration
  • Check left front window for visibility and operation of all windows
  • Check for incorrect sticker placement or other visual restrictions
  • Check glass to the left & right of the driver position for after-market tinting
Body:
  • Check integrity of floor pan and trunk area
  • Check frame and body mounts
Exhaust System:
  • Check vehicle muffler
  • Check for after-market uncertified muffler
  • Check for loose joints or leaking joints
  • Check for leaks caused by corrosion, seams, or patches on muffler or tailpipe
  • Check tailpipe end for restrictions
  • Check for exhaust system modifications allowing excessive noise
  • Ensure no part of the exhaust system passes through the passenger compartment
Fuel System:
  • Ensure system is securely attached
  • Check for vapor or fuel leakage
  • Check for proper routing of fuel lines
  • Check fuel tank and/or auxiliary fuel tank, or jug stored in vehicle
Emission System:
  • Check catalytic converter if so equipped
  • Ensure fuel cap is present and secure
  • Perform OBDII check (1996 & newer vehicles - use CAN protocol scan tool)
  • Fill out OBDII form
Old Mar 28, 2014 | 09:09 PM
Old Man with a hemi's Avatar
Old Man with a hemi
Originally Posted by dirtydog
I'm shocked the Feds haven't made it mandatory for all states/counties etc by now!
It will happen at some point or another.
In Tennessee, only counties that touch a county that has a major city in it, are emission tested. So Nashville, Knoxville Memphis and maybe Chattanooga, and surrounding counties are tested, the rest of us are left alone, and hope it stays that way.
Old Mar 29, 2014 | 08:49 AM
SLT8's Avatar
SLT8
In the manual there is a ignition sequence to test if your i/m monitors are in a readiness state.
Old Mar 29, 2014 | 12:20 PM
dirtydog's Avatar
dirtydog
Moderate User
Yup, already stated in Post #3.
Originally Posted by Pedro Dog
For Jeep, Chrysler and Dodge, the owner’s manual states that the vehicle has a simple ignition key actuated test, which you can use prior to going to the test station. To check if your vehicle’s OBD II system is ready, you must do the following:
1. Turn the ignition switch to the “ON”position, but do not crank or start the engine. If you crank or start the engine, you will have to start this test over.
2. As soon as you turn the ignition switch to the ON position, you will see the MIL symbol come on as part of a normal bulb check.
3. Approximately 15 seconds later, one of two things will happen:
a. The MIL will flash for about 10 seconds and then return to being fully illuminated until you turn OFF the ignition or start the engine. This means that your vehicle’s OBD II system is not ready and you should not proceed to the E-Checkst ation.
b. The MIL will not flash at all and will remain fully illuminated until you turn OFF the ignition or start the engine. This means that your vehicle’s OBD II system is ready and you can proceed to the E-Check station
Old Mar 29, 2014 | 02:40 PM
SLT8's Avatar
SLT8
Oops.sorry bout that.
