Fog light install question
Old Mar 29, 2014 | 10:44 PM
Heminoob's Avatar
Heminoob
Default Fog light install question
Bought myself a newer Ram (traded in my '03 for a low-mile 2011 at the dealer) and started the farkling. Put on a bush bar and mounted up a pair of cheap 55w fog lights from Princess Auto (Canada's version of Harbor freight). Bought a wiring harness with the fuse, relay, and switch set-up for ease of install.
Got everything wired up perfectly EXCEPT for a little red wire running from my switch along with the black one and the white one. The instructions say to splice the red wire in to my low beam or highbeam or fog light wire, depending on how I want them to come on. Problem is, I don't have a Haynes manual and I have no idea where any of those wires are except where they come right off the connector behind the bulb. I want to set up up so my off-road fogs come on when I push the button for the OEM fogs to come in. Would it be easiest for me to just pull that switch off my dash and wire up the red wire to that switch? Has anyone else done this and found a better/easier place to wire up their switch to?
Thanks in advance for any ideas.
Old Apr 1, 2014 | 11:30 AM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
If you're installing non-OEM (cheaper) fog lights, its a good idea to wire them on their own independent circuits and not splice into the vehicle harness.
Old Apr 2, 2014 | 12:12 AM
NV290's Avatar
NV290
I agree with this. Not worth the risk. Read about the Dodge TIPM and you will understand why. Any decent auto parts store will stock everything you need to do an install completely independent of the factory electrical system minus the connection to the battery.
