Squeaky doors!
Old Apr 17, 2015 | 02:35 AM
OCDPLR's Avatar
OCDPLR
My 2010 1500 had bad squeaky doors for a while and I used a teflon spray lube on them. After doing that a few times I haven't had to spray it for a couple years.
Old Apr 17, 2015 | 07:51 AM
oldjeep's Avatar
oldjeep
I have to do my drivers door about every 6 months, haven't had an issue with the other 3.
Old Apr 17, 2015 | 08:41 AM
Dusty48's Avatar
Dusty48
No squeaks from the doors yet on my 2014. On the 2010 I had to oil the drivers door pivot about once a year. But the brake pedal has squeaked on both the '10 and the '14. The '10 had no grease at all on the brake actuator shaft (where it meets the brake pedal arm). On the '14 it just isn't enough.
Regards,
Dusty
2014 Ram Big Horn 1500 Quad Cab 2WD, 5.7 Hemi, 8HP70, 3.92 LSD, factory dual exhaust, 20” wheels. Now at: 018144 miles.
Old Apr 20, 2015 | 03:31 PM
Jeffs09's Avatar
Jeffs09
I use clean motor oil (5w30 or?) in a small hand pump. I've never once heard a squeak from mine in the 6 years I've owned it. Whatever you use, it needs to be runny to lubricate the bushings.
Old Apr 22, 2015 | 10:21 PM
capsfloyd's Avatar
capsfloyd
x 2 on the teflon spray
