Help!!!! 4x4
Old Jul 20, 2014 | 06:47 AM
hookemkirk's Avatar
hookemkirk
Default Help!!!! 4x4
My 2011 ram 4x4 does not engage. My back tires will spin free for a long period of time but no movement from my front tires at all. Ive tried all modes and get the same results. (4wl , 4wLOCK & 4Auto) can someone please tell how to resolve this issue ?
Old Jul 20, 2014 | 11:30 AM
Duso02's Avatar
Duso02
Are you verifying this by putting it on a lift or jacking it up?
Old Jul 21, 2014 | 12:46 PM
hookemkirk's Avatar
hookemkirk
Default help 4x4
Yes sir will lift it uo this evening.
Old Jul 21, 2014 | 09:40 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Check the fluid.
Old Jul 22, 2014 | 12:22 AM
hookemkirk's Avatar
hookemkirk
Default update
So I lifted the truck up and all four tires were spinning correctly. I stopped the driver side tire and the passenger did not speed up like it was supposed to. So I tried the opposite , come to find out the front driveshaft was not spinning anymore so I went back inside the truck to check everything out now it has a" serv 4wd " light . Turned the truck off and back on and the code was gone so we tried again. Me and a buddy got underneath to see if we could here any noise coming from the transfer case. We couldn't here anything at all only the front solenoid. My buddy thinks its something jn the transfer case that might be causing this problem. I didnt want to take it to the dealership because I think I have vioded my warranty by putting a 6" suspension lift on the truck. But what do u guys think of this situation ?
Old Jul 26, 2014 | 12:30 PM
Duso02's Avatar
Duso02
They will need to prove the lift caused the problem. 6" will be extra wear on components as they are not designed for it but worth a try.
Old Jul 27, 2014 | 10:46 AM
hookemkirk's Avatar
hookemkirk
The lift definitely isnt the problem. ...the problem was the transfer case. They did not tell me exactly what though.
