Overhead console green light led ashtray cup holder
Old Sep 14, 2014 | 01:59 PM
Dusty48's Avatar
Dusty48
Originally Posted by tadst34
I stuck with green.
Yes seems strange for an led to flicker. But it was the led. I checked the voltage at the harness. I also used a multimeter with a diode tester to check the led. Led was bad.
Light Emitting Diodes can flicker. This occurs when there is a contaminate at the junction of the diode. It's rare, but I've seen it before in various electronic equipment.
Regards,
Dusty
2014 Ram Big Horn 1500 Quad Cab 2WD, 5.7 Hemi, 8HP70, 3.92 LSD, factory dual exhaust, 20” wheels. Now at: 008200 miles.
Old Mar 9, 2019 | 01:51 AM
JoshuaAckley's Avatar
JoshuaAckley
I can't believe I waited around this long to fix this. Finally got my LEDs in this week. Ordered a red, green, and natural white. I am trying the white first. I just cut the leads down to a more manageable size, shoved them in the clip, and taped them. I started the black insert from the outside, and taped the LED right over the hole it shines through. I like the white, but I'll know better on Monday when I drive to work.
Edit: I ended up changing out the white for the green. The white was too bright, and the green matches the rest of the truck.
Old Jan 2, 2021 | 05:47 PM
Asakhan's Avatar
Asakhan
how did you guys manage to make It so the light comes on when the car lights are on and goes off when the car is off?
Old Jan 2, 2021 | 05:56 PM
JoshuaAckley
I used the connection for the existing overhead light. It only comes on with the headlights.
Old Jan 2, 2021 | 06:48 PM
Asakhan's Avatar
Asakhan
So the led from super bright LEDS has the same connector that’s in the ram?
Old Jan 2, 2021 | 07:04 PM
JoshuaAckley
No, I just stripped some wire from the LED, inserted into the connector and taped it up, so it wasn't permanently modified. It's worked since my last post without doing anything to it.
