Levelling kit
Old Aug 1, 2014 | 11:06 AM
Arich1's Avatar
Arich1
New Member
Default Levelling kit
Does anyone know what best levelling kit for 2014 ram don't want spacers?
Old Aug 7, 2014 | 12:31 PM
Silver_Dodge's Avatar
Silver_Dodge
Bilstein 5100's.
http://www.bilsteinus.com/fileadmin/...WebArticle.pdf
Old Aug 7, 2014 | 08:33 PM
MoparMan1991's Avatar
MoparMan1991
I'd be interested as well, however I'm wanting to drop the rear to match the front instead.
Old Aug 21, 2014 | 04:29 PM
Whiteout08's Avatar
Whiteout08
What is the reason for not wanting spacers? I think the only coil type lift is either the 5100's as mentioned, or the Rancho "Quick Lift".
I ran the TGC 2.5" front and 3/4" rear kit, the ride was just the same as stock, and install was very straight forward.
Old Sep 2, 2014 | 11:37 AM
gopackgo69's Avatar
gopackgo69
Pro Comp offers a lift strut for the Rams, slighty cheaper then the Bilsteins. This is what I am running and am very happy with the ride quality.
Old Sep 5, 2014 | 03:05 AM
duke07's Avatar
duke07
To me, spacers are still a better choice since it is cheaper and won't affect the ride quality of your rig. Unless you are planning to go off-roading, you may not notice a difference.
Old Sep 9, 2014 | 07:43 PM
tommyexpress's Avatar
tommyexpress
Smile lift
I used the hell bent 2 1/2 spacers and love it, eazy and alignment was no problem. did a 2" spacer in the back too
Old Sep 9, 2014 | 09:02 PM
MoparMan1991
The OP already stated that they did not want to use spacers.
Old Sep 11, 2014 | 02:12 PM
Johnn123's Avatar
Johnn123
Originally Posted by Silver_Dodge
+1 on the bilstein 5100's. Adjustable lift struts. I believe procomp also offers a lift strut, the pro runners but they are not adjustable and static at 2.75". Bilsteins you can set at .7", 1.4", 2.1", 2.8".
Old Sep 15, 2014 | 11:40 AM
gopackgo69's Avatar
gopackgo69
You would want a lift shock over a spacer. Why you ask, because the stock shock is a cheaply made twin tube design. Bilsteins and the Pro comps are high quality monotube shocks that are high pressure nitrogen charged. Your ride will be greatly improved over stock shocks. I upgraded my rear shocks and used Fox 2.0. Bilstein also makes 5100 for the rear.
