seat heater intermittent issue
Old Sep 9, 2014 | 09:11 PM
rolltidehemi's Avatar
rolltidehemi
Default seat heater intermittent issue
just wondering if anyone else had an issue with one of their seat heaters, my driver side heater button lights up for a couple of seconds then turns off, but every now and then it stays on and works, checked connections but same condition persists! Anyone have similar?
Old Sep 10, 2014 | 08:45 AM
DodgeCares's Avatar
DodgeCares
Here is information on the heated seat system from the service manual. The dealer can further inspect as they will have the scan tools to diagnose issue.
DIAGNOSIS AND TESTING - HEATED SEAT SYSTEM
NOTE:Vehicles equipped with the heated seat option utilize a low voltage cut-off feature. This feature turns off power to the heated seat system anytime vehicle voltage is below 11.7 volts or above 15.5 volts. Be certain to check the vehicle electrical system for proper voltage anytime the heated seat system appears inoperative.
NOTE:If a Diagnostic Trouble Code (DTC) can not be verified, it is a good indication that an INTERMITTENT fault condition may be present. To help find an intermittent problem, sit in the seat in question and move around the heating elements within the seat while testing continuity. also wiggle the heated seat wire harness and electrical connectors while testing continuity.
NOTE:For complete circuit diagrams, see Wiring Information. Wiring Information includes wiring diagrams, connector pin-out and location views, details of wire harness routing and retention, splice and ground locations and proper wire and connector repair procedures.Before testing any individual components in the heated seat system, check the following:
Old Sep 10, 2014 | 08:51 AM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
That symptom usually indicates a short (overcurrent) in the seat heater circuit. On a 5 year old truck, I would bet the element in the cushion is kinked or about to break somewhere.
