Different type of High Beams not working
Old Sep 12, 2014 | 09:45 AM
Old_enough_to_remember's Avatar
Default Different type of High Beams not working
I did a search for high beams not working and found nothing like my problem, if there is one I missed it.
I have 2009 1500 base model, no bells or whistles and nothing added. I live way out in the country where deer and fallen limbs are the biggest road hazards at night so having working high beams are a must.
My high beams quit working. The lows work just fine. When I pull back on the high/low beam column stalk to "flash" the highs for passing the high beams come on. So I know that both high beam bulbs are good and the wiring is ok. They just don't work when I push the stalk forward to go to only high beams.
I checked out the fuse box under the hood but couldn't decipher which one might be a "light" relay or fuse. I don't want to go taking the steering column apart to get to the switch just yet if there is something more simple to check first.
Anyone know what I should check for or had similar problems?
