Factory Stereo Problem
Old Sep 17, 2014 | 12:28 AM
redbiddymax's Avatar
redbiddymax
Default Factory Stereo Problem
Okay so I bought a used 2009 Ram 1500 SLT Crew Cab. It has the factory stereo in it. My problem is that after driving a few minutes the entire stereo shuts off and I have no control to turn the stereo back on. After turning the truck off for a few hours it may or may not turn back on. Does anyone have any clue as to what I can do at home to fix this problem? Since it was used I don't have any warranty from the Dealership for them to fix it free. I pulled the face off the dash to check if there were any loose wires behind the stereo. Everything is plugged in and not loose. Any other ideas?
Thanks in advance.
Old Sep 17, 2014 | 02:50 AM
redbiddymax
Also where is the ground for the stereo located? Thought I would give this a check at home too.
Old Sep 17, 2014 | 11:25 AM
BigBlueEdge's Avatar
BigBlueEdge
Sounds like it may be overheating. Perhaps there is a cooling fan in the radio someplace that has malfunctioned.
If you recently purchased the truck and this started happening right away maybe go back to the dealer you purchased it from and see if they'll help out.
There is a separate fuse for the radio. You could pull that the next time it goes out and see if that resets it. If it does then it isn't overheating (assuming you do the fuse thing right away).
Rob
Old Sep 17, 2014 | 10:01 PM
bluebeast1562's Avatar
bluebeast1562
I concur with Rob, check the fuse. Could just be pushed in a little and with vehicle motion, pops out.
Old Sep 17, 2014 | 11:36 PM
redbiddymax
Yeah tried the fuse, fuse was fine and even put a new one in just in case it was a bad fuse. Fuse definitely not the problem.
I did pull the stereo out and noticed the outer casing of the stereo was extremely hot, much more hot than any car stereo should feel so maybe the fan is the problem. I'll check with the dealer and see what they come up with.
Old Sep 18, 2014 | 10:14 AM
jawsdc's Avatar
jawsdc
Mine (2009 REN Laramie) has done the same thing before. Always related to exterior heat in my case.
Here's the good news, it probably will not be a problem when it cools off and it may somehow correct itself. I have not had the problem return for 2 or 3 years. I have MaxCare and it's covered under warranty but has not been a problem so I have not even worried about it.
Good Luck
Old Sep 23, 2014 | 08:28 PM
Mikeyyy816's Avatar
Mikeyyy816
Thanks in advance.
I have an old Res radio with u connect capabilities and sat ready (the res is the stock radio non touch screen) just sitting on the bench in my garage depending on your location I'll practically give it to you for a few bucks and if you paid shipping. Obviously if the dealer won't help you out. Let me know.
