Do I need to get my Speedometer recalibrated?
Old Oct 2, 2014 | 03:24 PM
James_thiessen83's Avatar
James_thiessen83
Default Do I need to get my Speedometer recalibrated?
So I went from having P265/70R17 tires on my truck and changed them out to P275/55R20's and I was wondering if I should have the speedometer recalibrated so the shift points and such are still proper?
Old Oct 2, 2014 | 03:28 PM
James_thiessen83
Also I should mention my truck 2012 Dodge Ram 1500 ST
Old Oct 2, 2014 | 03:34 PM
HammerZ71's Avatar
HammerZ71
Tire is barely more than a quarter inch taller, nah won't make a bit of difference to the transmission.
Difference on the speedo won't even be enough to mean the difference of getting a ticket or not...
Old Oct 2, 2014 | 03:35 PM
If you have a smart phone, get you an app that reads speed and gor a drive. See if there is a difference between what it says and what your speedo says. Decide from there.
Old Oct 3, 2014 | 07:34 PM
kayakman's Avatar
kayakman
Just what hammerZ71 said James - a couple 10ths of a mph at 62 mph/100kph
http://www.1010tires.com/Tools/Tire-...5R20/275-55R20
Old Oct 5, 2014 | 11:48 AM
mike2810's Avatar
mike2810
Discount tire has a calculator
http://www.discounttire.com/dtcs/infoTireMath.dos
looks like you tire changes makes about a 0.62 mph diff.
old tires 65 mph
new tires 65.62
Not worth the time to change, imo.
Old Oct 6, 2014 | 06:19 PM
James_thiessen83
Thanks everyone. Means I'm just going to leave it alone.
Old Oct 8, 2014 | 09:32 AM
iskybantilus's Avatar
iskybantilus
not to hijack this thread, but i presume the trucks have something to compensate for what wheels/tires the come with since the difference beween at 265/70-17 and a 275/60-20 is even bigger?
programming or a different gear somewhere?
Old Oct 11, 2014 | 10:32 AM
Duso02's Avatar
Duso02
Back in the day it was a physical geared drive in the trans. You could adjust the speedo by buying a gear-drive with more or less teeth to adjust the ratio. Now, with electrical systems, it's a simple programming step for the dealer.
Old Nov 12, 2014 | 08:34 AM
smess's Avatar
smess
don't waste your time and as soon as the tire gets a 1000 miles on it, it will be the same size as the stock tire. some tires run tall and some short so you are chasing your tail
