2009 5.7L Spark Plug Question
Old Oct 12, 2014 | 01:33 PM
HogRidinFool's Avatar
HogRidinFool
New Member
Default 2009 5.7L Spark Plug Question
I want to change the plugs in my truck and purchased a set from the dealer.
My question is, the plugs that I am removing are NGK and have the compression washer that seats to the head and the ones that the dealer sold me are Champion (copper), but they don't have the compression washer. Is that a concern? Did they give me the wrong plugs?
Old Oct 12, 2014 | 03:44 PM
Pedro Dog's Avatar
Pedro Dog
I'm surprised that the dealer sold you champions as the OEM are the NGK with the compression washer. I've done my plugs twice and got them from the dealer both times and the dealer supplied the NGKs. I would call the dealer and ask them if the have the NGKs and ask for them. I like the compression washer for the sake of the installation as it does not require a torque wrench. Using the torque wrench on the backs ones is basically impossible.
Old Oct 12, 2014 | 09:03 PM
HogRidinFool
New Member
Thanks for the reply Pedro. I'm taking them back and requesting the NGK's.
Old Oct 13, 2014 | 08:51 AM
HogRidinFool
New Member
Just to follow up, I did stop at the dealer this morning and they DID sell me the wrong plugs. Go the correct ones (NGK) and will be installing this weekend. Thanks
Old Oct 15, 2014 | 04:05 PM
capsfloyd's Avatar
capsfloyd
i have 230,000 miles on my 09 . since 45,000 i have ran platniums in the truck ... no problems .... 100,000 plugs .... less changings
Old Oct 18, 2014 | 02:06 AM
cyclone429's Avatar
cyclone429
champions are used in third gens....Been running plats the day my 06 was off the books and never had any issues. oem plugs x 16 don't last any more than a year in my hemi, yes their cheap, but swap out a set two or three times your self or at dodge and Platts are not so expensive.
Old Oct 27, 2014 | 03:04 PM
HogRidinFool
New Member
Talking
Just updating my original post. Been a week or so since the install and I can actually feel the difference in performance.
Old Oct 27, 2014 | 03:57 PM
Pedro Dog's Avatar
Pedro Dog
Did you also clean the throttle body, it will make the idle real smooth. Another thing I tried to do was to put the ECM into a relearn mode. Not sure If I was successful as I used the 3rd gen method of disconnecting the battery negative and turning the ignition key to on. Be on notice that you will not be able to remove the key until the battery gets reconnected.
