Old Aug 13, 2015, 08:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting Guides
Print Wikipost
Turn signal bulb replacement
Old Oct 21, 2014 | 09:12 PM
706jim's Avatar
706jim
Default Turn signal bulb replacement
How do I replace a rear turn signal bulb on a 2010 Ram Sport?
Old Oct 21, 2014 | 11:02 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
You have to take the whole lamp out. There should be 2 fasteners holding it in ..let the tailgate down.
There are 3 bulbs in a socket "tower" that is held to the back by 3 T-20 screws.
Old Oct 22, 2014 | 08:52 AM
oldjeep's Avatar
oldjeep
Just make sure you pull the lamp housing straight back, other wise you'll need some new plastic retainer clips. (Not that I've done that - twice)
Old Oct 22, 2014 | 08:54 AM
NV290's Avatar
NV290
Open your tailgate and looking at the bed's edge near the tail light housings locate the two T20 (I believe it's T20) screws. Take them both out. Then using your fingertips pull the housing straight back carefully. On the outside edge (closest to the rear wheel) the housing is held in with rubber pockets that hold studs. It's a press fit. A little bit of wiggling can help.
Once the whole housing pops loose you will see how to remove the bulbs.
Old Oct 22, 2014 | 08:20 PM
706jim's Avatar
706jim
Thanks for the instructions. It sure was easier on my old Ford.
Old Oct 25, 2014 | 08:29 PM
706jim's Avatar
706jim
Bulb changed without any difficulty thanks to hints given here.
#3157 for those who might need a bulb. Clear one for brake and rear turn signal.
