Passenger Side Rear Quad Cab Door Lock
Old Dec 21, 2014 | 11:29 AM
moparonly0912's Avatar
moparonly0912
Default Passenger Side Rear Quad Cab Door Lock
Have a 2010 1500 Quad Cab, and all of a sudden the rear passenger door lock will lock with the fob and switch ok, but sometimes, more often than not, it wont unlock. It seems to work fine when it unlocks all the doors when i open the drivers door, but not when i use the fob or switch. warranty just ran out, so trying to wait before i go to the dealer... anything is appreciated.
Old Dec 23, 2014 | 09:30 AM
DodgeCares's Avatar
DodgeCares
There is a technical service bulletin 23-009-10 related to your issue. The dealer can inspect for the condition.
SUBJECT:
Rear Quad Cab Door Will Not Power Lock And Unlock
OVERVIEW:
This involves removing rear quad cab door trim panel and rerouting the power lock and
unlock wire harness away from the bell crank on the right and/or left side.
MODELS:
2009 - 2010 (DS) RAM 1500 Pickup
NOTE: This bulletin applies to vehicles built before April 15, 2009 (MDH0415XX).
SYMPTOM/CONDITION:
The customer may experience a condition where the rear quad cab door on the right and/or left side will not lock or unlock using the FOBIC or door panel switches.
NOTE: The rear quad cab doors will lock and unlock properly in all manual
operations.
