LOOKING AT BUYING A 4th Gen?
Old Apr 19, 2015 | 09:00 PM
dieselpower65's Avatar
dieselpower65
New Member
Default LOOKING AT BUYING A 4th Gen?
Im looking into buying a 4th gen 1500 What are the most reliable years. What are the common problems?
Any info is appreciated!!
Old Apr 20, 2015 | 03:21 PM
Jeffs09's Avatar
Jeffs09
I've got one of the early (March 2009) 4th generations. Problems I've had are:
Failed pinion bearing-leaking seal.
Rear axle retaining nut (recall)
HVAC controls (recall) still does not work properly.
Tie Rod ends failed (recall)
Exhaust manifold studs broken (TSB)
MyGig Radio issues, replaced once.
Keyless entry has never worked 100%. Dealer finds no issue.
Brake Rotors-rear calipers hung up.
Upper radiator hose-persistent leak. Worm gear clamp and rtv has stopped it.
61k miles-front strut seals failed
RF fender has begun to rot out directly in the center
Panel on top of dash has begun to get sticky
All in all, not too awful for a first year run, and far fewer issues than I had with my nbs 2007 Silverado. I would say get the newest model year that you can afford. The newer they are, the more bugs that get worked out.
Old Apr 21, 2015 | 05:21 PM
dwaldmann's Avatar
dwaldmann
Based on experience on other brands/models, the most reliable year will be the last year before the 5th Gen comes out. However, if you don't want to wait that long, the most reliable one is likely the current new model. If you can't afford that, buy the newest one you can afford.
Old Apr 22, 2015 | 10:20 PM
capsfloyd's Avatar
capsfloyd
09 for sure .... 258,000 miles on truck
