2012 powerwagon cat back exhaust.
Old May 13, 2015 | 05:39 PM
dwaldmann's Avatar
dwaldmann
Not many aftermarket exhaust shops deal in stainless. That's what the factory system is, and the only exhaust I would consider unless planning to keep the truck three years or less.
Old May 14, 2015 | 12:45 AM
NV290's Avatar
NV290
My non stainless exhaust was still fine after almost 4 years. And i live in New England. But any exhaust shop can get stainless if you ask them to. It typically comes in 10' lengths which means one piece should be all they need. Not that expensive.
Old May 14, 2015 | 06:42 AM
dwaldmann's Avatar
dwaldmann
They can get it, but most are not set up to work with it. I've asked several and they say they can't do it. I assume that it's A) harder to bend and B) you need a different welding setup.
Old May 18, 2015 | 09:32 PM
pwrwagon2012's Avatar
pwrwagon2012
What about converting a 3" exhaust from the outlet to a 4" pipe and run it to the bumper. What advantage or disadvantage is there?
Old May 19, 2015 | 11:19 AM
NV290's Avatar
NV290
4" Is way too big. It's a myth that having a much larger diameter exhaust will increase performance. In fact, it hurts performance. Magnaflow explains it quite well: http://www.magnaflow.com/07techtips/faq/question10.asp
Old May 20, 2015 | 03:49 AM
pwrwagon2012
Ok im a firm believer that there is no exhaust out there that will fit my powerwagon. Anyone out there with a solution please help.
2012 powerwagon
5.7 hemi
crew cab 6.4 bed
single side exhaust.
Still has leaf spring set up.
Old May 20, 2015 | 01:29 PM
dwaldmann's Avatar
dwaldmann
2012 powerwagon
5.7 hemi
crew cab 6.4 bed
Assuming that's true, you've already been given a solution. I would want stainless, but you didn't state a preference. And there are places that will do stainless, but they are fewer and further between. This isn't rocket science, just tubes.
I would look around and find a decent exhaust shop and have them build you an exhaust. It's not anywhere near as pricey as you might think. I had mine (on my 06') custom made to my exact liking and installed (fully welded) for $300. I opted for the exhaust exiting before the rear wheel but he said if i wanted to go over the axle and out the back it was only another $120.00.
Meineke shops are privately owned franchises. They have all the pipe and benders needed to do most anything. So even if you don't have a performance muffler place near you, just find a Meineke and talk to a manager.
Old May 20, 2015 | 02:45 PM
2012 powerwagon
5.7 hemi
crew cab 6.4 bed
Several potential solutions have been provided in this thread. If there is, in fact, no aftermarket exhaust available, your only option is custom made.
Old May 20, 2015 | 04:54 PM
BigBlueEdge's Avatar
BigBlueEdge
Perhaps you'd be better off just sticking with the stock system then? It has worked fine for me on my Hemi for 76K miles.
Rob
