Leveling kit problems
Old Oct 13, 2015 | 05:43 PM
beachbummer0069's Avatar
beachbummer0069
Exclamation Leveling kit problems
I ran into a problem after installing a 2 inch tough country leveling kit on my 2011 Ram 2500 Hemi. My factory trac bar will not go back into the oem bracket. It is about 2 to 3 inches from the holes lining up to put the bolt through. I bought an adjustable pro comp trac bar with drop down bracket to fix the problem. I took the truck to the dealership to get an alignment. The dealership told me the adjustable trac bar will not work. My front end is to loose now. When turning the tires right to left when on the ground the truck lifts. The whole front end feels free and loose. Can somebody help me or guide me in the right direction. I do not want to keep dumping money into it or have the dealership keep diagnosing it and charging me.
Old Oct 17, 2015 | 09:06 PM
stlhrscwby's Avatar
stlhrscwby
You probably need to put your truck up on jack stands, get a big pry bar and shift the front end over so you can reinstall the track bar. Your truck requires that you have one and will drive like crap till you get it hooked up not to mention its kind of dangerous.
Old Nov 20, 2015 | 10:01 PM
iwhitne's Avatar
iwhitne
you will then need to have an alignment because your steering wheel will be way off
