question on a fitting..
Old Nov 1, 2015 | 06:16 PM
badjojo13's Avatar
badjojo13
Default question on a fitting..
35x12.5R20 lt general grabbler at2
my truck is a 2010 1500 SLT crew cab 4x4 with a daystar front leveling kit only 2.5
RIMS : stock grey 20inch wheel I believe they are 20x8 not the sport wheels. grey ones.
will these tire fit with out rubbing, the guy at the shop said they will, but will have less then a 1/4 inch between the tire and upper arm claims he has done a few before, its a well known establish performance shop so I then to accept his input but want to make sure. is that 1/4 inch an issue or is that ok???
thanks in advance for your information.
Old Nov 4, 2015 | 04:07 PM
badjojo13's Avatar
badjojo13
alright the general grabbler 35x12.5 r20 did not fit, they where to wide and hit the upper arm. so I had to go with the bf all terrain ko2 not has wide but gives 35'' 285/65r20
Old Nov 4, 2015 | 04:20 PM
badjojo13's Avatar
badjojo13
Old Nov 4, 2015 | 07:15 PM
pitbull24's Avatar
pitbull24
Glad you got some 35's to fit.
A friend at work put a leveling kit & 35's.
I'll try to get details tomorrow.
Old Nov 5, 2015 | 08:45 AM
badjojo13's Avatar
badjojo13
they are not real 35'' they are 285/65r20 that gives 35'' but not nearly has wide and those not look has good ether i regret them i should have gone with the other and put spacer's they would have look much bettter. but to late now
Old Nov 5, 2015 | 09:42 AM
oldjeep's Avatar
oldjeep
Spacers on a nearly 3 ton truck are a really bad idea. If you feel the need for wider tires then buy some rims with the proper offset.
Old Nov 5, 2015 | 01:11 PM
badjojo13's Avatar
badjojo13
it’s nothing to do with winter tires. I’m just disappointed that the generalwhere to wide and did not fit. I should have waited for another option some35x12.5 are not has wide has others some fit without spacers. going with 285/65give 35 but there are so small that it looks somewhat weird. like and narrowtire...
Old Nov 5, 2015 | 09:17 PM
pitbull24's Avatar
pitbull24
I understand.
If it's any concellation, they do not look bad from the side.
Old Nov 6, 2015 | 08:24 AM
pitbull24's Avatar
pitbull24
My coworker used a 2.5" level kit. States the rear was also raised 1".
Tires are Goodyear Duratrck 315/70/17.
Old Nov 11, 2015 | 01:30 PM
ealemany's Avatar
ealemany
Thank you Badjojo13 for the pictures. The Tires look really nice.
Your truck looks like it is in a great condition. I will go with 285/65/20
personally I'd rather have the height than the width.
Thanks again
