Online Service Manual Problem
Old Nov 19, 2015 | 11:41 AM
jawsdc's Avatar
jawsdc
Default Online Service Manual Problem
Anyone else having trouble getting the 2009 Dodge RAM Truck 1500 Service, Diagnostic, and Wiring Information online service manual to pull up? Worked fine the last time i used it several months ago. Using IE (11) SVG Viewer installed
Old Nov 19, 2015 | 11:56 AM
jawsdc's Avatar
jawsdc
looks like it may be the IE version causing the trouble
Old Nov 19, 2015 | 12:02 PM
Pedro Dog's Avatar
Pedro Dog
Needs to run on IE8 I believe, SVG viewer is not supported in later versions of IE. Also needs to run on Windows XP. I'm sure there are work-arounds that I'm not familiar with.
I used to view it on Windows 7 running a ******* PC for windows XP. Moved to windows 10 and lost that.
Old Nov 19, 2015 | 04:12 PM
jawsdc's Avatar
jawsdc
Internet explorer updated unexpectedly on the newer PC. Looks like I'm going to have to keep the old XP around a little longer until someone is nice enough to link an updated online service manual platform.
Old Nov 20, 2015 | 04:14 PM
biggcrisp's Avatar
biggcrisp
https://www.fleet.chrysler.com/FleetHome/SpecialtyVehicleDocs/RAM_1500_SSV_Upfitter_Guide.pdf
You can go here without putting your computer into a low security mode.
Not everything. Still more than the average joe needs to do his own work.
It is a large number of pages and takes a while to download.
Chrysler moves it around -- so if the link stops working just google it.
Old Nov 21, 2015 | 07:53 AM
oldjeep's Avatar
oldjeep
You can get it to work with IE 11, basically you need to setup a local webserver and then access it through there rather than via c:\ it is a security issue where you cannot lower the security enough to run SVG viewer when the source is a drive. I am running it under Windows 10 without an issue.
Mine is accessed like this:
http://localhost/Service%20manual/co...ml/default.htm
Old Jan 31, 2016 | 09:40 AM
mopowa's Avatar
mopowa
Default Service Manual
I'd really like to know how you set it up as a local webserver. did you use Apache or something like that? Maybe you could do a post on it.
