Dead battery
Old Feb 8, 2016 | 01:18 AM
Matthew Hernandez's Avatar
Matthew Hernandez
Exclamation Dead battery
Need help guys. Got a 14 ram. Got some cheap hids. Installed them. Only to realize they flicker n shut off. N need a warning cancellers so to save me the trouble I just took them out and put back the stock bulbs. But now my frecken battery is dying! Anyone know what the problem could be. Many battery went bad or is it something more technical?
Old Feb 8, 2016 | 07:37 AM
Moving to the correct section. Please read the section descriptions before posting so you post in the correct section.
Have you checked the alternator and/or battery?? How old is the battery? Take the HID's out and see if it changes anything. On a side note, putting HID's in stock housings is not a good idea.
Old Feb 28, 2016 | 10:44 PM
cummins 6.7's Avatar
cummins 6.7
i had a similar issue where my batterys kept dying, later come to find out my hood latch sensor which is integrated with the remote start was bad..... so i fixed that sensor and batteries were all good again...
Old Feb 29, 2016 | 07:42 AM
xsparta11x's Avatar
xsparta11x
could also be a short somewhere. A constant short can drain a battery. But the post above sounds like a more likely issue.
