Code P0113 and P0300 help
Old May 16, 2016 | 06:07 PM
TheHMan's Avatar
TheHMan
Default Code P0113 and P0300 help
I have a 2013 Hemi. I was at the drive thru the other day and the truck just started idling really rough. The truck began shaking and a loud ticking sound started. The rough idle and ticking continues. The truck can not really run. When I try to give it gas while in park it takes a few seconds to rev up. Even then it is still sputtering and ticking. We put a lower end machine on it it and its reads 2 codes. The first is P0113 the air intake temperature sensor. The second is P0300 which is a random cylinder misfire. I am lost as to what the problem and fix are? Please help?
Old May 16, 2016 | 07:11 PM
Google those codes and follow the recommended procedures to test/replace. Fixed the title to something more appropriate to your issue.
Old Mar 19, 2020 | 04:43 AM
Stephen Palumbo's Avatar
Stephen Palumbo
wonder if you found a fix to this problem
Old Dec 22, 2023 | 09:37 AM
Ulisesm0226's Avatar
Ulisesm0226
Did you fix your problem, I have same problem with mine I can't fix it help please
Old Dec 22, 2023 | 01:45 PM
7 year old thread, OP has one post. Don't expect an answer.
Old Dec 23, 2023 | 05:11 PM
Ulisesm0226
Did you fix the problem?
Old Dec 23, 2023 | 07:11 PM
Seriously? Did you net see my post right about yours????
