MDS Delete
Old Oct 2, 2016 | 01:32 PM
Josh Barker's Avatar
Josh Barker
Arrow MDS Delete
I'm about to replace my camshaft and lifters in my 2010 Dodge Ram 1500 Hemi, and I am probably going to delete the mds system as it has just caused the trouble I'm having. If I change the lifters, and don't use the deactivating lifters that the MDS requires, do I also need to wipe that from the truck's computer? Or do I need to still use the MDS lifters since the truck had them to begin with? Any help, much appreciated.
Old Oct 2, 2016 | 09:02 PM
iwhitne's Avatar
iwhitne
if you're change the cam for more power.. you should also change the lifters and get the computer tuned to eliminate the mds..
Old Oct 28, 2016 | 01:46 AM
Josh Barker
Changing the cam because the lifter locked and ate the lobe. Obviously I'm changing lifters. I want to use the cheaper non-deactivating lifters, because I want rid of the MDS. I just want to know if I can use those lifters in place of the deactivating lifters on an MDS engine.
