Truck Wont start or shift
Old Feb 24, 2017 | 08:20 AM
iamwill80's Avatar
iamwill80
Default Truck Wont start or shift
For the last 3 days my 2010 5.7 4x4 Ram was throwing the P0750 LR code then would enter limp mode. Today I installed a new (From Dodge) LR Shift Solenoid Pack part number 52119435AF. Changed both Trans filters and put new +4 ATF in.
When I turned the truck on it was in shift Lock. I over road the shift lock because the truck is on incline stands and I needed to back it down and check the ATF levels. When I overroad the Shift lock the truck locked into 2nd gear. Doesnt matter what position the shifter is in the truck stays in 2nd. P,R,N D all 2nd gear. Now because I shut the truck off, and its still in 2nd... It wont start back up because it needs to be in Park!
I tried disconnecting the battery but its is still stuck... Any help would be great.
Thanks guys!
