Rear Dome light issue
Old Apr 22, 2017 | 09:58 AM
Rado's Avatar
Rado
Default Rear Dome light issue Solved!!!!
2015 RAM SLT Quad cab The dome light above the rear seat does not work. The front map light do! Bulb is fine ever picked up a new one still NG.. No fuse listed in the manual so have no clue what it is hooked up to, Is it controlled by the computer? I did test for power and have 12v both sides of bulb to ground on 12v plug ! Will be going to dealer in a couple weeks to do winter tire swap if it ever stops snowing lol any idea where I can look?
Old May 13, 2017 | 02:32 PM
Rado's Avatar
Rado
WOW 189 lookers at this post and no one had any ideas on where to start or what it may be :O ,, I will update in case anyone else has a similar issue. It was a Ground Pin pushed out, Simple fix so I was on the right track
Old May 19, 2017 | 06:58 PM
Mattones's Avatar
Mattones
Did you figure it out? None of mine are working either
Old May 19, 2017 | 08:15 PM
Rado's Avatar
Rado
Yea the dealer fixed, the ground wire pin got pushed out. so a simple fix and best thing is no charge
